John Deere 70 LP VS Farmall F20!!!
Jonesy
01-30-2006 20:25:25
TRUE STORY
A guy brought a bakers fan to our show this past year. It had rained and was quite muddy. We belted up a WK-40 IH, W-30, Farmall C and my 1936 Farmall F20 on full steel. Hard to belt that old bugger up in the mud. Anyway the old 20 hadnt run smooth since I bought it so a good load is what it needed. The 20 could pull the Baker Fan %100 loaded. We ran it for quite some time until she boiled over. A fellow on a John Deere 70LP said he was next. After finally getting her belted up (JD'S not good in this dept. darn pullys always turnen) it slowly gets the fan up to speed. We begine to "load" the fan but the old 70 couldnt take it and the fan shut her down. They fellow quickly responds with " she aint runnin right". Hum sounds like the F20. For some reason none of the JD guys would hook up after that. Thats when they hooked a Farmall C up to really rub it in. Ill take a Farmall on the belt any day.
G/MAN
01-31-2006 07:31:27
 Re: John Deere 70 LP VS Farmall F20!!! in reply to Jonesy, 01-30-2006 20:25:25
I've got a news flash for you. If the "70" couldn't run the same load as a "C", it most certainly was NOT running right.
Jonesy
01-31-2006 08:07:50
 Re: John Deere 70 LP VS Farmall F20!!! in reply to G/MAN, 01-31-2006 07:31:27
Hillsboro TX, Memorial Day weekend, 2006, You and me, showdown on the belt, hahha. Im going to hook up my 41 JD B to the thing this year and wear that new shiny paint right off. None of the other JD guys with pretty tractors want to hurt their paint, what a shame. Ill have some Farmalls there too.
G/MAN
01-31-2006 10:07:00
 Re: John Deere 70 LP VS Farmall F20!!! in reply to Jonesy, 01-31-2006 08:07:50
I guess I'll have to get my "G" together, lol. If they don't want to wear the paint off the pulley, that's their business. I know plenty of two-banger guys that USE their tractors.
RalphinWI
01-30-2006 21:45:36
If you check you will find that the belt speed for two cylinders is much higher than for a McCormick. The John Deere runs the fan at a much higher speed than the McCormick. If I remember correctly the silage cutter (stationary at the silo) used a 14" pully for McCormicks, while the John Deere needed a 21 or 22" pully on the cutter.
buickanddeere
01-31-2006 14:59:33
 Re: John Deere 70 LP VS Farmall F20!!! in reply to RalphinWI, 01-30-2006 21:45:36
Jonesy can't do math either. He doesn't realize that that a Baker fan's load increases to the 3rd power with relation to rpms. For example, if the driving pulley was changed from 10.0" to 12.26" and the rpm kept the same. The baker fan would require twice the HP to operate. The operator of the 70LP should have known better too. Did a bunch of students, now adults. Skip math in high school or drop out of high school?
billde
01-31-2006 18:59:52
 Re: John Deere 70 LP VS Farmall F20!!! in reply to buickanddeere, 01-31-2006 14:59:33
If the fan takes twice the horsepower it should have been a pretty even match between a 70 and a Farmall C. The 70 has more than twice the HP of a C or an F20.
buickanddeere
01-31-2006 23:07:39
 Re: John Deere 70 LP VS Farmall F20!!! in reply to billde, 01-31-2006 18:59:52
The 70 tries to drive the baker fan a lot more than 1.26 times faster than the C.
buickanddeere
01-31-2006 23:06:41
The 70 drives the baker fan a lot more than 1.26 times faster than the C.
