4010 POWER STEERING PROBLEM
FARMER-C
01-30-2006 19:38:13
I JUST BOUGHT A 4010 AND THE POWER STEERING
TAKES A FEW MINUTES TO BUILD PRESURE TO WORK
AND THE 3 PT TAKES TIME TO MOVE UP ALSO
THANKS BRIAN
Tx Jim
01-31-2006 03:48:44
 Re: 4010 POWER STEERING PROBLEM in reply to FARMER-C, 01-30-2006 19:38:13
Farmer-C,the hyd oil is bleeding back to sump. I know 4020's had a check valve to prevent this from occurring but I don't remember if 4010's did. After you start tractor be sure foot clutch is engaged as then trans. pump turns. Tx Jim
Bob
01-31-2006 04:00:41
 Re: 4010 POWER STEERING PROBLEM in reply to Tx Jim, 01-31-2006 03:48:44
third party image
Here's the check valve in a 4010. It is inside the rear end, on the LH side, just ahead of, and beside the differential. It is just after the transmission pump in the circuit.
Key #'s 34, 35, and 36.
andy from ILL.
01-30-2006 19:53:15
I hate to admit this but my 3010 has the same problem. Power steering does not work right away and the 3-pt doesn't work right away either. I am assuming since it is the type of hydralic pump that John Deere uses in them that a valve in the pump is sticking. What it will take to fix I hope some one here can tell us.
4010guy
01-30-2006 21:43:05
 Re: 4010 POWER STEERING PROBLEM in reply to andy from ILL., 01-30-2006 19:53:15
dont know for shure but thear is a gear pump in the rear end that i have broke gears on that feeds the main pump----then thears the priorty pump that can stick--hate to admit this to ha! lol know how u feel,,,,//
