620LP Crank end play
Ben.So.Tex
01-30-2006 19:30:26
Nephew is looking at a 620LP, The crank moves about1/4-3/8 inch when you enguage the clutch.
Can this be remove by moving the flywheel inward? I have done this on my Bs to take it out.
Thanks Ben
8e3k0
01-31-2006 06:38:28
 Re: 620LP Crank end play in reply to Ben.So.Tex, 01-30-2006 19:30:26
Please note that if you are watching the clutch pulley there is a certain amount of end play in the pulley assembly to engage and disengage your clutch combined with actual end play of crank. Best way is: remove the flywheel cover and check end play with a dial body mounted to the tractor crankshaft casing ( under/on governor assembly) and the dial indicator on the flywheel. Engage clutch and move clutch lever back and forth without disengaging clutch, it's a bit easier with a second person to read dial at the flywheel. Differential reading of dial should be 0.004 to 0.010 of an inch with a max up to 0.012.
For a quick method you can grasp flywheel (with gloves on), then try to push and pull flywheel in and out to see what type of reading you obtain on the dial. Good luck with your venture! Ellis
REDJD
01-30-2006 20:25:52
Yes,moving the flywheel is what you need to do. I think the correct end play is no more than ten thousands.I would suggest you make this adjustment and then run the engine some before buying it.If the crank is worn or the flywheel or both, it won't stay.
