8n 12v conversion
mikethefin
01-30-2006 18:33:55
Do I need a 12 volt coil if I use a resistor? and do I need to change my condenser? and I could use a diagram for a single wire alt. It is a left side mount.
old
01-30-2006 19:35:23
 Re: 8n 12v conversion in reply to mikethefin, 01-30-2006 18:33:55
Think your in the wrong forum. But to answer your question if you use a 6 volt coil you need a resister, if you use a 12 volt coil you don't need a resister. Also the condenser doesn't need to be changed..
John T
01-30-2006 19:34:49
Nope, if you use a series external voltage dropping (12 to 6) Ballast Resistor (around 1.5 to 1.85 ohms and 25 to 30 watts), then you can still use a 6 volt coil on a 12 volt system.
Nope, the condensor for a 12 volt system would be near the same as for a 6 volt, no need to change. The voltage withstand rating of the condensor for a 6 or 12 volt system is wayyyyy yy higher then 6 or 12 volts anyway.
If you use a true one wire alternator, its output simply wires to the load (NOT to battery/starter) side of the ammeter.
John T
Bob
01-31-2006 14:51:03
 Re: 8n 12v conversion in reply to John T, 01-30-2006 19:34:49
John,
The original Ford "6-Volt" coil differs from MOST other 6-Volt battery ignition tractors in that it already uses a ballast resistor, and the coil operates at around 4 Volts. Be sure to tell him to keep his original ballast resistor, PLUS add the "converting resistor" you suggest in series with the original resistor.
The fifth diagram from the top, at the site linked below shows how to connect the two resistors into the ignition system.
