70 lb compact JD weights
720Deere
01-30-2006 15:06:21
Does anybody know the JD part number for the 70 pound compact tractor weights. I have searched through the parts catalogs for virutally every compact on JDParts.com and I can't find anything for the 70 pounders. They always list the 40 lb but never the 70 lb.
jd2830
01-31-2006 03:47:54
 Re: 70 lb compact JD weights in reply to 720Deere, 01-30-2006 15:06:21
what is the part # on the 40 pounders
jdp
01-31-2006 06:24:54
 Re: 70 lb compact JD weights in reply to jd2830, 01-31-2006 03:47:54
40 lb R66949
720Deere
01-31-2006 06:29:21
 Re: 70 lb compact JD weights in reply to jdp, 01-31-2006 06:24:54
My dealer lists the R66949 40 lb weight for $39.59, but you can get the R66949Y for $35.95. It is the same weight just yellow for the skidloaders. We have been buying the yellow ones to save a dollar since even the green ones are usually so beat up that we need to paint them anyway.
jdp
01-30-2006 15:16:46
Looked up my 4710, 70 lbs weight BM19780 is what JD parts shows
720Deere
01-30-2006 15:25:06
 Re: 70 lb compact JD weights in reply to jdp, 01-30-2006 15:16:46
Thanks a ton!
