4020 Power Steering
Larry Nickel
01-30-2006 09:13:29
I inherited a '70 4020 diesel tractor from my dad. The power steering has started to act up, not allowing me to turn to the left and also now it is hard to turn to the right. Is this a steering pump problem?
donmyeil
01-30-2006 12:48:58
 Re: 4020 Power Steering in reply to Larry Nickel, 01-30-2006 09:13:29
The trouble you have is the sandwich plate is leaking oil where it isnt supposed to. This is not a repairable part so the plate needs to be replaced. These steering valves are not as difficult as everyone would have you believe. With proper tools and know how they are a piece of cake. I would overhaul one of these everyday . yes I ocasionaly goof up but who doesnt?
G/MAN - oh, and what's...
01-31-2006 10:19:16
 Re: 4020 Power Steering in reply to donmyeil, 01-30-2006 12:48:58
...this "sandwich plate" you're referring to? The plate between the valve section and cylinder section? Why does it need replaced?
G/MAN
01-31-2006 10:18:10
No, they're not especially difficult to rebuild IF you have the know-how and tools. The point I was trying to get across is that if you don't have the tools and a manual, you're going to be lost in a heartbeat, and will be beating your head against the wall in no time. And if you're going to make a career out of them, you'd better have the hose and gauge setup to test the valve before reinstallation, unless you like rolling the dice that it'll work the first time. I've probably only done 5 or 6, and only had real problems with the first one, and unfortunately that shop didn't have the test set-up, so it was in and out a few times. That pretty much soured me on them. Now that I work in a shop that DOES have the test set-up, I've never had one fail to work the first time. Go figure.
G/MAN
01-30-2006 10:23:36
There are some tests that can be done to verify, but more than likely it's a problem in the steering hand metering unit. They can be a bit of a trick to rebuild and set properly, so unless you have experience with them and are pretty handy and have access to the special tools for adjusting the valve clearances, your best bet (if it's indeed the valve) is to either take the whole tractor in for diagnosis and service, remove the valve for service, calibration and testing, or purchase a rebuilt exchange unit from somewhere like Abilene Machine. I haven't met a JD technician yet (I am one myself) that has any real love for rebuilding those valves. They work great and many tractors will run for decades without the valve requiring service, but when they decide to act up, they can do it really well, and render the tractor unsafe or impossible to operate.
SuperHank
01-30-2006 12:29:30
 Re: 4020 Power Steering in reply to G/MAN, 01-30-2006 10:23:36
This is not the same question GMAN but my 2020 does not turn as far to the right as it turns to the left. I found the center of the number of turns (approx. 2&3/4 turns lock to lock) and at the center of the turns the wheels are not centered.(a little too far right) Obviously this makes it hard to turn right tightly. Got any ideas how to fix this?
Tx Jim
01-31-2006 04:14:55
 Re: 4020 Power Steering in reply to SuperHank, 01-30-2006 12:29:30
Super Hank,are your tie rods adjusted same length on each side? If I remember correctly the bellcrank arm on steering valve can only be put on correct position. The bellcrank bolt can be accessed through hole in LH side of clutch housing. Tx Jim
G/MAN
01-30-2006 15:40:06
I'll have to look at some 2020 pics to see exactly what steering system they use, but if there's a big difference in turning angle and if the tractor has a steering motor like say a 3020 (I'm not familiar with the 2020 to any great degree), it's possible that someone got the steering arm spindle out of time with the ram when they reassembled it at some point. Deere steering motors use a rack-and-pinion setup with the rack being on the hydraulic ram and the pinion being the shaft the steering arm mounts to. If the pinion isn't centered in the ram, it can cause the situation you're describing. I can do some more checking and get back to you.
SuperHank
01-31-2006 08:18:07
 Re: 4020 Power Steering in reply to G/MAN, 01-30-2006 15:40:06
Thanks for the response. It looks like you have a lot of experience with 20 series JD. The tie rods can be adjusted but it seems that the problem is, like you said, and old incorrect reassembly. I appreciate any advice you have. If you like you can reach me at [email protected]
G/MAN
01-31-2006 10:25:41
 Re: 4020 Power Steering in reply to SuperHank, 01-31-2006 08:18:07
Hank, is your tractor power-steering or manual steering?
G/MAN
01-31-2006 10:10:01
Not much experience with the New Generation "worldwide" tractors like the 1010, 2020 etc., but quite a bit of experience with the Waterloo New Gens - the 4010, 3020 and on up.
SuperHank
01-31-2006 12:54:19
 Re: 4020 Power Steering in reply to G/MAN, 01-31-2006 10:10:01
Power steering 1968 I think it is the closed system (separate pump) It had a leak recently that caused hydraulic fluid to be pumped into the crankcase. It runs well but there is a little play in the wheel.
SuperHank
01-31-2006 08:12:13
SuperHank
01-31-2006 13:02:16
 Re: 4020 Power Steering in reply to SuperHank, 01-31-2006 08:12:13
It looks like it is an open system from futher reading on the topic. In other words, I'm not certain whether its open or closed system but I think it's open.
