JD 1935 A
curtis todd
01-30-2006 08:39:40
I just bought a 35 JD A and wanted to know if there was a way using the serial # to find out which plant is was built at and what equipment it had on it. IE (steel or rubber,flat or round spoke,power-trol)
Big_Roy
01-30-2006 14:21:14
 Re: JD 1935 A in reply to curtis todd, 01-30-2006 08:39:40
Just a note, if you do the Two-Cylinder research don't go into it expecting the equipment that it came with to be noted. When I had my 34 A checked they told me that that info wasn't always recorded, but I bought it for the original owner and he was able to tell me about it's history.
littleh
01-30-2006 10:43:37
all of the horizontal two-cyld. deere tractors were built in waterloo IA. the JD collector"s center or two-cyl. mag can run a sn# check to see what your tractor came with. those services are going to cost @ $25
J.R. Hobbs
01-30-2006 15:20:15
 Re: JD 1935 A in reply to littleh, 01-30-2006 10:43:37
No, a serial number search doesn't cost $25. The cost is $12 per serial number for members of the Two-Cylinder Club, and $20 for non-members. You'll get all the information that is available for your tractor, which varies from year to year and model to model, and it's printed out on high-quality paper suitable for framing, if desired.
curtis todd
01-31-2006 03:56:13
 Re: JD 1935 A in reply to J.R. Hobbs, 01-30-2006 15:20:15
This is a new hobby for my wife and I so I'm not a member of a two cylinder club yet, but do you have a phone # or website address to get a hold of them? Is it thru the JD Collectors Ccenter like LittleH said? Thanks
J.R. Hobbs
01-31-2006 04:16:29
 Re: JD 1935 A in reply to curtis todd, 01-31-2006 03:56:13
The JD Collector's Center does not provide the serial number searches. You can reach the Two-Cylinder Club at: 319-824-6060, or www.two-cylinder.com. Welcome to the hobby!
