Delco generator differences
JDVan
01-29-2006 23:09:41
Anyone on this list know what the real differences are between these two 6V Delco
generators?
Delco # 1101371 used on B's 96000 to 200999 with cutout relay
Delco # 1101385 used on B's 60000 to 95999 with cutout relay
Both use the same:
Armature 1841027
Field Coil Set 19002102
Main Brush Set 1880998 Third Brush plate 809698
Relay 11166809
etc, etc
But use different:
Frame Commutator End 1882356 vs 817216
Frame Drive End 1882358 vs 817223
What is different about the frame ends? Do they have a different mounting
dimensions? My guess is the generators are electrically identical.
Thanks for any help in advance.
PS: Notice I have been able to get my hands on some Delco reference
literature but I still have unanswered questions! :-)
Bob Collins
01-31-2006 14:30:21
 Re: Delco generator differences in reply to JDVan, 01-29-2006 23:09:41
In the 1960s I worked at an auto supply dealer who was an official Delco-Remy dealer. We had a manual of bulletins about 6" thick at that time. It had information on what seemed to be any change ever made to a Delco part. The years may have clouded my recollection, but if you could find one of those manuals, I think you might find what you want to know.
Glen in TX
01-30-2006 09:04:05
JDVan, Looks like you answered it to me and yes the end plates are different on some with mounting ears being lower or higher or offset some or threaded or drilled hole. Some can be made to fit other tractors and some can't. Most Delco manuals aren't going to show you any differences in their books but the part number. Some end plates used a bushing and later ones used a ball bearing and 2 brush or 3 brush also. A old Lester manual for electrical rebuilders might? Might also find out in B parts book and I don't have one to look in for you. Good luck.
