Fuel shut off for model 60.
mike 154
01-29-2006 19:20:22
Did the 60 have the automatic fuel shut off like a 620 as standard equipment? Mine has a conventional sediment bowl / manual shut off lever like my farmall H has. I'm beginning to work on it and would like it to be correct.
Thanks, Mike
G/MAN
01-30-2006 10:27:57
 Re: Fuel shut off for model 60. in reply to mike 154, 01-29-2006 19:20:22
If it is supposed to have the oil-pressure shutoff and you install one, just make sure it's in good shape, as with age the seals can begin leaking and negate the entire purpose of the valve.
mike 154
01-30-2006 09:38:16
Thanks, guys. It appears I have the correct one-as mine is an early 53 model.
Mike
fred from MO
01-30-2006 01:56:00
My 60 is a 1953 and it has the automatic oil pressure shut off like your questioning.
ACRookie(SC)
01-29-2006 20:43:07
I've never seen a 60 with an (oil pressure) fuel shut off like the later model tractors.
Carl NY
01-29-2006 20:39:43
Mike, it appears the factory used the shutoff system you have up to tractor SN# 6028468. At that point they used the automatic shutoff system. It is possible some of the early tractors were converted in the field by the dealers.
