speed control rod position
kenc
01-29-2006 17:51:49
I am repositioning my speed control rod on my 1936 model d tractor. the speed rod end which is an elbow shape is positioned into a tab that moves linkage to the carb. my question is what position should the speed rod elbow be with the tab. Should the tab/elbow be in the down, side or up position? Hope i described this matter properly.
thanks,
kenc
01-30-2006 04:47:47
 Re: speed control rod position in reply to kenc, 01-29-2006 17:51:49
Thanks again Glen, Just a point of clarafication, I am refering to the speed control lever side where the long rod and elbow connect to the linkage tab. What position is the tab where the elbow connects to it? Again, I hope I have explained it properly.
regards,
ken
Glen in TX
01-30-2006 09:16:09
 Re: speed control rod position in reply to kenc, 01-30-2006 04:47:47
Ken, On the long rod from throttle lever the rod would slide in lever towards center of tractor and on farther front by rod across governor the threaded elbow would slide in that rod facing away from tractor. Email me if you want a pic showing the throttle linkages.
kenc
01-31-2006 14:07:04
 Re: speed control rod position in reply to Glen in TX, 01-30-2006 09:16:09
hi glen,
i would appreciate sending me a photo or two to help me get over this mental block that i have.
Best regards,
Glen in TX
01-31-2006 14:28:02
 Re: speed control rod position in reply to kenc , 01-31-2006 14:07:04
Ken, I sent you a email. Have illustration of the linkages on styled D that are the same.
kenc
01-30-2006 04:47:28
regards,
ken
Glen in TX
01-29-2006 21:01:52
The rod part at carburetor points down and the threaded elbow part by governor will point up with cotter on top of governor lever.
