axle felt
Ken Tabor
01-29-2006 16:25:41
I have three stamped metal pieces that mount on the end of the axle housing. Two have the four screw holes that go into the cast housing One is a smaller stamped piece that also goes around the axle. I can't seem to figure out the order that they go on over the axle etc. The manual is not clear on the assembly. I have a sneaky suspicion that I have the felt and other spacers on wrong and will have to remove the whole axle again. Anyone seen a good assembly picture.
Maark
01-30-2006 11:43:53
 Re: axle felt in reply to Ken Tabor, 01-29-2006 16:25:41
Parts book shows the bearing, spacer, retainer, felt, and the outside retainer. In that order. Looks like a shoulder on the spacer next to the bearing.
Ken Tabor
01-30-2006 06:06:26
I forgot to mention it is a 1946 model B. I am beginnig to think that there is a spacer that goes on the axle shaft at the beginning of assembly. I think I put it on backward but would like to make sure on assembly before I take it all apart again.
Maark
01-29-2006 17:16:00
What model are you working on?
