EDISON-SPLITDORF MAG REBUILD?
TIMAR
01-29-2006 10:08:31
Who does the best, reasonably priced rebuilds of magnetos?
buckeye al
01-30-2006 14:21:06
 Re: EDISON-SPLITDORF MAG REBUILD? in reply to TIMAR, 01-29-2006 10:08:31
I did like Toot said when I worked on one from a guy's old D. After a lot of careful TLC cleaning, oiling, greasing, polishing (points) & when finished, I was impressed with its behavior. The D was happy too!
toot
01-30-2006 06:22:14
I had one on a 38 G. It would not fire, and like the gentleman said, you could not find parts. I was only used to working on WICO mags. So..... I tore it down slowly to remember how to reassemble it. I cleaned everything, filed the points as smooth as I could, put it back together. It fired hotter than most mags I had fooled with. I didn"t replace any part on mine. I would try myself before I gave up or spent a boatload of money for a rebuild. Make sure to keep the gears and drives lined up. I made a mark with a paint pen on the gear and rotor.
Glen in TX
01-29-2006 13:41:24
They quit making ES mag parts long ago and not so available now. New gaskets, rewound coils, new bearings, capacitor condenser, & oil seals are about all you can find new for them now. ES CD mags and early Splitdorf take more time and labor to fix right. What is your labor and time worth? If you expect it fixed for the same cost as a simple Wico keep dreaming.
Biltwell12-24
01-29-2006 11:07:54
I use JWB Machine & Magneto out of Bettendorf, Iowa. His name is John. 563-370-1757.
JRB
01-30-2006 15:19:54
 Re: EDISON-SPLITDORF MAG REBUILD? in reply to Biltwell12-24, 01-29-2006 11:07:54
I also use JWB machine/magneto in Bettendorf. He's done dozens of them for me. I couldn't recommend a better man to do your work. What he doesn't know isn't worth knowing!
