70 pistons in A block
johndeereboy
01-29-2006 06:09:09
Has anyone heard of boring out an A block from 5 1/2 to 5 7/8 to hold 70 pistons. I guess what I am asking is will an A block hold up to being bored .375 over.
Lynard
01-30-2006 17:16:26
 Re: 70 pistons in A block in reply to johndeereboy, 01-29-2006 06:09:09
johndeereboy I have been running one in an unstyled A that I pull for 8 years and it is still going as strong as when it first started running. 70 pistons are a lot shorter but mine is stroked 2 inches and welded rods are longer than stock. If you try and run the pistons higher in the block without stroking top ring grooves will go past plugs. Lynn
Drew
01-29-2006 09:01:54
It can be done, if you have a GOOOOO OOOOD block. On the other hand, I have hit water at +.125". Like B&D said, get it sonic checked, but it is still possible that you will find a casting flaw/tiny pin hole. Most, if not all of the 5.875" A's I have heard of are unstyled, supposedly the bores are cast thicker, dont know how true that is though.
Maark
01-29-2006 08:47:51
Isn't the 70 piston shorter than the A piston or pin location different, thus resulting in a shorter stroke?
G/MAN
01-30-2006 10:33:36
 Re: 70 pistons in A block in reply to Maark, 01-29-2006 08:47:51
Stroke is controlled by the crankshaft. Changing pistons has no effect on the actual stroke, but as buickanddeere said, it will affect the compression height and compression ratio.
buickanddeere
01-29-2006 17:52:09
Stroke is the same, compression height would change.
buickanddeere
01-29-2006 06:37:06
A well equiped machine shop can sonic test the block wall thickness. No use spending your money to have water cooled pistons.
