Is BW or BN designated by the serial number?
used to be jame
01-28-2006 05:29:53
On the letter series JD's, was the wide front or single front designated in the serial number?
Was the original wide front round or square? Was the spare axle aftermarket or just later model?
Thanks
95EB
01-28-2006 12:21:32
 Re: Is BW or BN designated by the serial number? in reply to used to be james, 01-28-2006 05:29:53
No, the tractor type was not encoded into the serial number. You will have to run a serial number search to find out if your tractor was a "B", "BN", or "BW". The "square" front axle wasn't introduced until the Model "70" tractor, in April, 1953, though with the correct bracket plate, it could be retrofitted to any "B" Series tractor with the two-piece pedestal assembly.
used to be james
01-28-2006 13:25:22
 Re: Is BW or BN designated by the serial number? in reply to 95EB, 01-28-2006 12:21:32
Thanks for the info.
Where do you run the serial number search? I've never heard of that. What all can you find out about a tractor? Can you find out about any tractor or just some?
95EB
01-28-2006 16:09:24
 Re: Is BW or BN designated by the serial number? in reply to used to be james, 01-28-2006 13:25:22
The Two-Cylinder Club offers serial number searches for almost all two-cylinder tractors, and most JD tractors through 1984. The cost is 12 dollars for Club members, and 20 dollars for non-members. The information available varies from model to model, and year to year, but in the case of your "B", the least you would get is build date, configuration (B, BN, BW), fuel type, ship date, and shipping destination---perhaps more, depending on the year. Call 319-824-6060 for more information.
CLW
01-28-2006 10:13:14
The serial number did not tell what type front end the tractor had. The round wide front was standard on the letter series wide front tractors.
Answer?
01-28-2006 09:33:03
Square(?) rear axle was a later model. I think the square front axle came only on the numbered series.
Maark
01-28-2006 09:08:59
No, round,What spare axle?
used to be james
01-28-2006 10:46:06
 Re: Is BW or BN designated by the serial number? in reply to Maark, 01-28-2006 09:08:59
I did not mean to type 'spare', I meant "square."
