310a backhoe oil pump info
captfatboy
01-27-2006 13:35:51
can any one tell me on this 310 a backhoe (219)
the oil pump has a o ring on the side where the tube come out leading into the block but I dont see an o ring in the block or on the other side of the tube that goes into the block and it isnt tight is that normal...?
thanks
Jonathan in MA
01-27-2006 14:15:22
 Re: 310a backhoe oil pump info in reply to captfatboy, 01-27-2006 13:35:51
Not sure what the initial problem was... but check the balancer shaft bushings while the pan's down ... push up and down on them to see if there is noticeable movement . You can lose an awful lot of oil pressure with worn shaft bushings.. Also get a new regulator spring and regulator.. Its the piece that fits into that threaded hex plug on the front timing cover. If its still the original in there, there is a "newer" style with accompanying spring.
captfatboy
01-28-2006 14:27:11
 Re: 310a backhoe oil pump info in reply to Jonathan in MA, 01-27-2006 14:15:22
Jon no problem I just had to replace the cylinder sleaves and while I had it down I went ahead and replaced pistons all barrings. just don't remember having this much play in the oil tube when I disassembled to remove the front main cap don't want to cut any corners and ruin a engine with a sloppy fitting oil tube .
HTR
01-28-2006 17:30:32
 Re: 310a backhoe oil pump info in reply to captfatboy, 01-28-2006 14:27:11
The early 219 did not use an Oring in the block. If there is any wear on the pipe, where it goes in the block, replace the pipe.
Jonathan in MA
01-27-2006 14:05:01
It may be gone or whats left of it is hard as a rock... stick a small pick in there and see if there is anything that you can break up.. Yhe oring part number is R75892 .. Its shown with a pic of the block... not shown with the oil pump
