4010 shift lever
wolfie
01-27-2006 12:21:01
I Have a early 4010 diecel. The problem I have is that sometimes the shift lever goes out of the shift range. By this I mean when I am in a certain range and cluch to get in the next range it sometime goes into that range but on the shift lever it is way out of the range.You have to really putt around with it before it will show and shift within the range. The shift lever seems to slip out of the range. like I could be in range three but the shift lever shows to be in the last range. You could not even shift into that range if you wanted to. Because the lever can not move any further down.
donmyeil
01-27-2006 12:49:26
 Re: 4010 shift lever in reply to wolfie, 01-27-2006 12:21:01
SOUNDS LIKE YOUR SHIFT ARMS,LEVERS QUADRANT BUSHINGS , PINS,RODS ARE ALL OR MOST WORN OUT. DOES THE SHIFT LEVER ITSELF HAVE GROVES ON IT. PUT LATE 4020 SHIFT DRUMS AND BLOCKER ON TO TIGHTEN THAT END UP. COULD HAVE DEEPER TROUBLE SUCH AS WORN SHIFTERS, BUT I WOULD WORK ON OUTSIDE FIRST
