720 1st reduction cover
J. Rand
01-27-2006 09:25:36
What's the best way to seal a leak in the 1st reduction cover. There is a small crack in the casting where it covers the PTO power gear. I saw oil leaking out when it was on the tractor, now it is off and dry, and I can't really even see the crack anymore. Thanks for the information.
Kevin L.
01-27-2006 10:48:31
 Re: 720 1st reduction cover in reply to J. Rand, 01-27-2006 09:25:36
could have been a paint crack and the leak was from another area or gasket. Would also run the sealing edges with a straight edge steel ruler and look for dents from with it could have been miss treated the last time it was off.
Mike M
01-27-2006 09:44:33
I have seen some that were brazed up in that area. Try putting some solvent or maybe soapy water in there then try to blow it through with an air hose ? It may show the crack ?
