2520 manual destroking kit
barnrat
01-27-2006 08:14:05
Does anybody know if you can still get a manual destroking kit for a 2520D. All that I can find on JDParts is an electric one. I called my local dealership and pimply faced kid(my usual parts guy has the flu) couldn't tell me anything either.
barnrat
01-27-2006 09:29:19
 Re: 2520 manual destroking kit in reply to barnrat, 01-27-2006 08:14:05
Thanks alot. I knew that there was one, just to blind to see what's in front of me. After all the problems I had starting that thing yesterday I figure I'll try to take some of the load off since jerking the steering wheel dosn't seem to be enough.
mitchp
01-27-2006 11:54:28
 Re: 2520 manual destroking kit in reply to barnrat, 01-27-2006 09:29:19
does it have the air intake warmer on it, where you push in a button and it goes "poof" and shoots heated air? mine starts really well after doing that, the destroker will help out too
mitchp
01-27-2006 09:01:08
I looked up the part on the JD parts website, looks like part # AR38225 will work, you'll have to take out the plug (R39112) on the top of the pump and put this in. If i remember right the plug took a 3/4" socket to unscrew it. i put one on my 2120 and its works good. Take the plug with you and make sure the threads are the same. Don't think you'll have any problems though
Bob
01-27-2006 08:51:56
If you go back to JDPARTS, for each of the option pumps, there is a manual destroke valve available.
Go to 2520/sectionalindex/hydraulics, and then determine which pump you have. Under the heading for that pump, find "stroke control valve", which will show the complete pump control valve assembly.
Off to the side, in a box, is the manual stroke control valve for that pump.
