310 a backhoe oil pump
captfatboy
01-27-2006 08:08:32
one more quick question since I have the engine down is there any way to check talorances in the oil pump or should I just replace regardless Big thanks to all that help me get this project completed Lee
captfatboy
01-27-2006 10:44:49
 Re: 310 a backhoe oil pump in reply to captfatboy, 01-27-2006 08:08:32
thanks gman sounds good
G/MAN
01-27-2006 10:12:27
I'm not familiar with what style of pump that engine has, but there are usually specs for gear or rotor clearance, etc. I'd definitely inspect it, and if there's no scoring on the gears or rotors or housings, you're probably good to go. An engine oil pump has to get in pretty rough shape to not be able to supply enough oil. In fact, they usually pump quite a bit more than the engine actually "needs", with the rest going out the bypass and back to sump.
