Info On SPOKER D mag
Howard Clark
01-26-2006 18:28:09
I need some help My question is, What is the proper series mag for a 1925 SPOKER D My tractor has a J series mag on it What can you tell me about this mag?
Glen in TX
01-27-2006 09:55:20
 Re: Info On SPOKER D mag in reply to Howard Clark, 01-26-2006 18:28:09
Just a word of caution after I saw some other Splitdorf mags advertised last night online. Many advertise them for a JD D when are they are not and don't rotate CCW facing drive end as they should. A CW, 46C, 4 cyld. mag won't work on your JD D and a CCW 4 cyld. with 2 grounded out is still not correct. They made the Aero Dixie 246C and Aero Dixie Splitdorf 246T just for the JDs with a 2 cyld. cap and they fit and turn correctly with correct impulse on them. Keep the FM-J mag as you may want it for a while yet.
Mike M
01-27-2006 05:17:05
While not correct for that tractor in todays world. If that is one of the later replacement FM mags. they have good parts availabilty and are a really good mag. and will make stronger spark than most others. Your tractor just may run the best with it ?
Glen in TX
01-26-2006 19:14:22
The older D then mostly came with the Dixie 246C mag but there was a period where some Fairbanks Morse R2 mags were used also but I'm not sure exactly when. Sounds like you probably have the Fairbanks Morse FM-J2A6 which was just a later replacement mag made in the late 30s into the 40s.
Parts are still available for the FM-J mag from the factory. The other two original mags are much harder to find parts for.
https://robertscarbrepair.com/maginfo.asp
Duane Larson
01-26-2006 19:08:22
Howard,
Your spoker D came with a Splitdorf Aero magneto, with the model 246C stamped on the oil cover near the impulse unit. The magneto has brass sides and a brass top - the later Splitdorf 246T has pot metal sides and top.
The 246C has an impulse unit which must be hand-set each time prior to starting. Impulse units were considered separate from the magneto in those days, and most units on spoker D's were built by K-W.
