'42 B horsepower
Smokin
01-26-2006 07:46:27
Can anyone tell me what is the horsepower rating of a 1942 model B and what size plow it can pull in average soil? Thanks for the help.
CMB
01-26-2006 12:17:38
 Re: '42 B horsepower in reply to Smokin, 01-26-2006 07:46:27
Dad bought a new B in Oct of '41. We used a 2-12 plow till after the war was over,& he could get the parts to convert it to gasoline(high comp cast iron pistons & a "cold" manifold). We then traded for a 2-14 plow,& got along fine, but by that time he'd also purchased a '29 D which pulled 2-16s very well.
Smokin
01-26-2006 11:50:26
Dear Deere friends,
Thank you for the HP information on the model B. I appreciate the help. --Bruce
Stan - Florida
01-26-2006 10:46:08
And to add to the opinions and confusion...our '43 B came on spade lugs and with a 1-16" plow. After the war (the Big One) and when the new "Cyclone" engine came out, we had it converted to the new style gasoline engine, had the spokes cut off and rims welded on, and moved up to a 2-12" plow. Our soil in central Indiana had a fair amount of clay on the high spots and some black gumbo in the low ground, so the old B worked pretty hard at it.
It was our only tractor from '43 to '49, and Dad and Grandpa put in a lot of hours trying to plow probably 150 acres each year. I was a little help, but I was only 7 to 12 years old in those days.
Stan
dbwillia
01-26-2006 08:19:47
Nebraska Test for a 1941 B shows 14.08 at drawbar and 17.46 on the belt. The 1942 would have the same horsepower. Dad had a 1941 B and a 2-14 plow that he used with it. Plow and tractor were both on steel, but I think B handled the job well, even though I believe steel would be a handicap over rubber tires.
DickD
01-26-2006 08:14:56
Sorry I didn't answer both parts of your question. Must have been a senior moment--- !938-- 1947 shows14.03HP Drawbar--18.53 belt
DickD
01-26-2006 08:05:44
If you are going to use a pulltype plow, no larger than 2 14's in most soil.
Mike M
01-26-2006 08:05:02
I don't have any figures but those early styled B's were pretty low in HP in original all-fuel form. But if you have one with gas pistons they really come alive.
A good late B 47' and up will play with a 2x14 plow. I would think you should still be able to pull a 2x14 plow with your older one just not as fast.
steveormary
01-26-2006 09:02:57
 Re: '42 B horsepower in reply to Mike M, 01-26-2006 08:05:02
smokin
We pulled 2-14"s with an F-12 so a B should be able to pull 2-14"s.
steveormary
