2520 starter wont stop turning
barnrat
01-26-2006 04:38:25
Ok here is the situation. Have this 2520 sold, guys supposed to pick it up today. I had to park the tractor outside last night. Plugged it in for about 45min went to start it and after tractor started the starter kept turning over. then fuel just shut off before I could turn the key off. Starter is still turning and bendix not engaged. Turn key off and starter still turns over. Had to disconnect battery cable to get it to stop. The starter looks fairly new. It"s bout 12 degrees outside and I don"t feel like doing alot of trouble shooting. My first conclusion may be the small black block just above the starter by the brake pedals, I think it"s a circut breaker. someone please tell me I"m heading in the right direction.
ET
01-26-2006 04:45:42
 Re: 2520 starter wont stop turning in reply to barnrat, 01-26-2006 04:38:25
It sounds like the soleniod stuck. Try taping it with a hammer to get it to pop loose. The contact disk has spot welded itself to the contact studs.
