Bio diecel jelling up
Dave NE IA
01-25-2006 22:30:01
I am sorry if this is not the correct place to post this unrelated subject. I wonder around YT and sometimes forget where I have put my foot prints, but usualy search the green breathing guys first.
Our fire department just decided on a major debt for the rest of our lives probably. I guess the new larger trucks are going to have to meet real tough emission control real sudden like. So we decided to jump and save the estamated $7,000.00 additional cost. Another item was the emmisions filter ( no idea what they were talking about) would have to be sent in and not thrown in the trash. Suggested that it was a very expensive ordeal to maintain.
I asked if we could burn Willie Neson's fuel and did they ever jump down my throat as apparently they have not got it suited for cold weather. Two of the truckers burned my ear good because they had to change out their fuel filters along side of the road or after the wrecker hauled them in. Some of the others suggested that many companies tried it and hoped to help our country help itself, but had to give in and go back to sand sucked fuel. Do any of you farmers especialy grain farmers have better reports? I was sad to hear this as our comunity is getting more like a (CROP FAILURE) or a town without any people as jobs are difficult to find at best. Dave NE IA
old bones
01-27-2006 19:43:55
 Re: Bio diecel jelling up in reply to Dave NE IA, 01-25-2006 22:30:01
Yes, biodiesel will gel at higher temps. The biodeisel folks say that themselves on their website (I can't remember what it is, but do a search on biodiesel or soyblended diesel). I would assume that your fire trucks are in a warm building most of the time (ours are). Not a problem until you take them out to fight a fire on a sub freezing night. You might find out if your fuel tanks are heated. If so, you shouldn't have a problem, but check it out with the mfgr (they all seem to have their little quirks about what will and will not work). I run a 2% blend in my farm tractors, and they don't like anything below about 20 degrees.
Also, if your pumper has air brakes, consider installing an air hose connection to the truck and hooking up to a compressor when parked. We did after the first call, when we had to sit and wait for brake pressure to build up. We had the connection right below the drivers door so it had to be disconnected when getting in (you know, the adrenilin thing that happens at 3am).
old bones
Tsmith1499
01-26-2006 20:36:43
John Deere is sending ALL of their deisel tractors out the door with a 95/5 biodeisel int hem and they recomend it.
billde
01-26-2006 05:27:14
We have been running bio diesel blend, its at about 11% now, for several years. There have been no problems as a winter blend is availble just like for straight diesel. Any form of vegetable oil will gel quicker than petroleum based oil, but it is controllable. Your fuel supplier should be able to give you an additive to treat summer fuel that will eliminate gelling.
Kevin L.
01-26-2006 10:13:57
 Re: Bio diesel jelling up in reply to billde, 01-26-2006 05:27:14
most people with problems from biodiesel probably did not do much research on it, just put it in and the miracle drug failed. Most all publication on biodiesel say because it's more of a solvent it will loosen the junk and trash in the fuel tank and fuel system to cause premature stoppage of the fuel filters, til this junk is trapped and removed by the filters, may even cause problems with trash in injectors. The long usage of pretroleum diesel the long it takes to stabilize with biodiesel. Now thinking of running 100% and not a blend will depend on the manufactures warranty and support of the product and wont support more the 20% bioblend. also biodiesel quality will depend on how much washing is done to it to remove the methanol and Red Devil Lye to leave biodiesel fuel..
