4010-4020 diesel engines
Richard 55
01-25-2006 18:26:27
Does anyone know if there is a difference between the 4010 and the 4020 engines? I have heard that a 4010 can be overhauled to produce the same hp as the 4020.Could not find any thing in the forums I am sure it has been discussed before. Thanks for any help.
msb
01-26-2006 18:26:21
 Re: 4010-4020 diesel engines in reply to Richard 55, 01-25-2006 18:26:27
Apples to apples-----4010 horsepower was rated at 540 PTO RPM.4020 horsepower was rated at 620 PTO RPM.SO even if your 4010 injection pump was set to 4020 specs ,you need to check the 4010 at 620 PTO RPM as well or you won't think your 4010 is producing as much power.
K.B.-826
01-25-2006 18:59:11
4010 was 380 cubic inches, 4020 was 404. 4010 just had a smaller bore. As far as I know, all 4010 overhaul kits come with 4020 pistons and sleeves.
CMB
01-26-2006 05:49:43
 Re: 4010-4020 diesel engines in reply to K.B.-826, 01-25-2006 18:59:11
I'm under the impression that 4020's also had slightly larger valves.
dp in nd
01-26-2006 17:46:44
 Re: 4010-4020 diesel engines in reply to CMB, 01-26-2006 05:49:43
When you get sleeves and pistons, they will be 4 1/4 inches to get 404 cu, maybe have turn up pump a little to get 4020 fuel setting.Dale
