Gernerator into alternator?
farmerboy
01-25-2006 15:50:43
Posted this on Johnnypopper.com as well.
I talked to a local shop about rebuilding the generator in my 60. He said I should let him turn it into an alternator. Says he does it all the time for owners of "off brands". He claims if I change the tractor to negative ground, switch the wires on the ammeter, and let him put an electrical regulator on the gen after he rebuilds it, it will charge like an alternator. Sounds too good to be true.
Does this sound like it would work? If it would and it's that simple, why hasn't everyone done it?
jdemaris
01-25-2006 19:57:13
 Re: Gernerator into alternator? in reply to farmerboy, 01-25-2006 15:50:43
It can be done but to my knowledge, there is no gain. A generator, by nature of design, only uses about half the power it is capable of making - as compared to an alternator. That is because it supplys DC current without the use of rectifiers - and it does that by selectively choosing electrical pulses in only one direction. An alternator uses much more of what is available since it uses the both phases of current, i.e. the alternating current in both directions, and then runs it though rectifiers to convert it into direct current. That is why, with similar sized units, an alternator is usually twice the output of an generator. As far as I know, when a DC generator is hooked up as an alternator, there is no output gain - just more sophisticated controls. Also, in regard to an alternator's need for field current. That's not completely true, generators and alternators can both self-field from residual magnetism. Generators do so at a much lower RPM. The Delco 10 or 12 SI alternators are capable of self-fielding, but they need to reach close to 3000 RPM to do it, which is not very practical. Thus the field energizer is used.
John T
01-25-2006 17:49:59
Farmer, Im not quite sure what all hes gonna do, but I tend to doubt hes really turning it into a true alternator. It can be done and they are available but pricey I bet. Of course, if it stays a genny it wouldnt have to be changed to Negative ground. Its not all that expensive to just rebuild the genny, especially if all its needs is the typicals set of brushes, maybe a new bushing and the commutator cleaned up. If it needs fields and an armature, however, then its big bucks.
John T
farmerboy
01-25-2006 17:55:36
 Re: Generator into alternator? in reply to John T, 01-25-2006 17:49:59
Hi John,
Yeah I really didn't dislike it as a generator. As long as I was above an idle and not using lights, it charged OK. I'll pry just fix it.
buickanddeere
01-25-2006 17:28:48
The later 50,60 & 70 were equiped with the 20amp Delco. If the belt wasn't glazed, the pulleys worn and the regulator set to 13.8 to 14.2V. They do a fine job of charging the battery. Unless the driver is one of those cheapskates that only idles the engine and shuts the engine off to save gas when opening a gate etc.
farmerboy
01-25-2006 17:51:55
 Re: Generator into alternator? in reply to buickanddeere, 01-25-2006 17:28:48
Buick,
Yeah I didn't have any complaints with the generator but, since it needs repair, now would've been the time to convert. I think I'll just have him fix it.
Whats wrong with shutting the tractor off while opening and closing gates?!? ;-P
buickanddeere
01-26-2006 15:04:53
 Re: Generator into alternator? in reply to farmerboy, 01-25-2006 17:51:55
Extra draw from the battery and less time spent charging it. You cannot take more from a battery than what is put into it. A battery subjected to just a partly charged state, rarely fully charged has a short life.
Glen in TX
01-25-2006 16:37:40
It's being done. Don't know what they are putting in them for sure. Maybe some little import alternator stuck inside the old case? I would sure ask them the price first. Explore the site below for some info.
Boy
01-25-2006 23:10:56
 Re: Gernerator into alternator? in reply to Glen in TX, 01-25-2006 16:37:40
Boy, that's a tight-lipped outfit... no photos or details, just buy our product, and you'll be happy!
Glen in TX
01-26-2006 09:15:24
 Re: Gernerator into alternator? in reply to Boy, 01-25-2006 23:10:56
It's a secret? shhhhh. lol. I'm not associated with them. When you look at the amps output of their units on other page I was not impressed for the prices. If you really need more charging output just go with the 20 amp original generators and new regulator for show or a alternator conversion for a working tractor and not show.
farmerboy
01-25-2006 17:57:53
Holy wowsers!!!! 800-some bucks to make a generator into an alternater?!? Fixing looks to be the way to go.
Glen in TX
01-25-2006 18:04:32
 Re: Gernerator into alternator? in reply to farmerboy, 01-25-2006 17:57:53
Yep, you can do lots of fixing on your tractor for what one of those would cost. lol. We got into a discussion about solid state cut outs and regulators on johnnypopper and that link got posted there. I believe those are for the old car purists.
machinery-man
01-25-2006 16:12:07
alternators rely on a power source....and use a stator...never heard of this setup....I will say a good late model generator should handled your charging needs...I think the 60 had the improved generator anyway....you need a regulator...can set up as negative or positive ground....changing wiring positions....
