Governer Model 50
STEVE PHELPS
01-25-2006 08:29:52
I pulled gov hsg cover and found cast on gear to hold weight broke. Chunks of metal from weight all over the place. I rcovered most larger chunks I am sure some made it to crankcase.Since there is no pan.How do you recommand removing or flushing out metal?Is there parts available for this repair other than john deere? I need shaft,gear, weights,brass bushing,and outer brg.THANKS for ALL the help!!!!! !!!!
Carl NY
01-25-2006 14:17:19
 Re: Governer Model 50 in reply to STEVE PHELPS, 01-25-2006 08:29:52
Steve,it sounds like alot of metal pieces were or are still in places they will cause more damage. I usually flush pieces out with fuel oil. This may take a few rinsings plus some air blasts. I have a 50 governer housing complete if interested. You should check the hydraulic pump gear drive & shaft also. The weights are made of lead.
F-I-T
01-25-2006 08:43:07
Steve:
Start out by posting a really thorough description (Model number, and serial number) of exactly what you need on the classified page here. Also contact any salvage yards near you or there are many people here can recommend to you.
Do this only after checking the parts book for any significant serial number changes. You will probably be able to find a complete shaft from a salvage tractor. Now, you might even find it is more economical to find a complete governor housing. The only potential problem with this fix is that you can run into t heel and lash and wear pattern mismatch when you mate the old fan shaft gear to the salvage gear. The correct fix would be to press the straight gear and then the bevel gear off of your old governor shaft and install the old bevel gear onto the newly acquired shaft. It takes a bit of press work, and you should have a dial indicator to set the lash after setting the heel by touch. You should really have the fan shaft off of the tractor to do all of this setup work. It's a lot more labor, but it result in a complete and dependable repair.
Some folks even go the distance and just get the fan shaft that was hooked to the salvage governor case. A little rework, cleaning and servicing, and you have a unit that will probably last another 50 or so years.
On cleaning the crankcase, once you have to governor off you can get your head down closer to the crankcase plate opening. Drain the oil, and then rinse the crankcase out with some solvent, then some light solvent so it evaporates to dry. You can then reach in and pick out any pieces of governor weight, old corn husks, gaskets, cotter pins, and maybe even find an old wrench (I speak from personal experience). You can even put duct tape sticky side out on a yard stick and touch the debris and get it out that way.
It's not too tough a job, but you'll probably be back with more questions. Just make sure you set the gears correctly or they will digest each other.
Frank
CFWelles
01-30-2006 03:01:39
 Re: Governer Model 50 in reply to F-I-T, 01-25-2006 08:43:07
Frank, how often do these lead weights tear up? Thats why I took my governor all apart on my 730. Opened it up to take out the shaft to replace the nylon tach drive gear set because I wanted to get a working tach/hour meter. Found the lead mess and then proceeded to do a complete removal. When I set up the gear set with new gaskets, I got the lash down to .007 and called it good. Edge of gears was perfectly aligned. Think they refer to thsi as being square. Spec is .002 to .006 I believe. By the way, I acquired a spare matched set of gears from a 70D. They are old number, but believe they are absolutely identical to the 730D. Is this correct?
CFWelles
01-30-2006 03:05:44
 Re: Governer Model 50 in reply to CFWelles, 01-30-2006 03:01:39
Spare set of gears I am referring to is the bevel set for fan drive. Realized that these needed to be matched as I believe you pointed out in your comments. Used my set over, but they had a fair amount of wear on them and discovered that these are obsolete. Bought a spare set out of a 70D from 2CylFan and they are in better condition than mine.
