'36 D Fan Shaft Bearing
Douglas Conrady
01-25-2006 07:00:53
Good morning.
I am needing to replace the front bearing of my fan shaft. Can anybody email or tell me what bearing I need to replace this with? My email is [email protected]
Thanks for your time,
Douglas
Maark
01-25-2006 07:51:29
 Re: '36 D Fan Shaft Bearing in reply to Douglas Conrady, 01-25-2006 07:00:53
JD7656R is the bearing cone, JD 7655R is the bearing cup. You can probably take those #'s to a bearing supply store and cross them over if needed.
Douglas Conrady
01-25-2006 09:13:47
 Re: '36 D Fan Shaft Bearing in reply to Maark, 01-25-2006 07:51:29
Thanks for the info. Do you know if there is a newer 1 piece style bearing available?
Thanks again,
Douglas
Douglas Conrady
01-25-2006 13:28:04
 Re: '36 D Fan Shaft Bearing in reply to Douglas Conrady, 01-25-2006 09:13:47
Glen,
Thanks for that bit of info. I had just gone out and bought a sealed bearing. I will return it and get the 3 part shindig. In your description it makes sense why a sealed wont work.
Thanks again everyone,
Douglas
Glen in TX
01-25-2006 11:47:57
It is a 3 piece thrust type ball bearing and has a retainer with balls also not mentioned.
JD7657R Retainer w/ balls
JD7656R Cone, inner
JD7655R Cup, outer
Same bearing on the other end of fan shaft at governor and also same at each end of governor shaft. The spring on front holds the preload on bearings keeping them inline and slack out for the beveled drive gears in the governor housing. You would have to remachine and re-engineer the whole thing to put a one piece bearing in and a bearing like that on just one end won't work and will ruin the gear alignment & gears most likely. You adjust the gears by thick and thin gaskets for shims at the governor bearing holders.
Unstyled D manuals: I&T JD-4 shop manual, JD DIR225 instructions & repairs of D 31-38, & PC658 Parts catalog.
www.awbearings.com/awbearings/
www.motionindustries.com
