Equipment size for 3010
Brian Setlak
01-25-2006 00:54:26
I up graded from a Super M to a 63' 3010 gas this past fall. What size equipment was a 3010 designed to pull. Disc, Plow etc. Just got a great deal on a MM 13' disc for a 100 bucks, but it looks to big behind the 3010.
Thanks
BushogPapa
01-25-2006 06:24:18
 Re: Equipment size for 3010 in reply to Brian Setlak, 01-25-2006 00:54:26
If you use Duals and avoid 1st time over plowed ground, you should be fine... 1st time over plowed ground should be with a good Soil Surgeon to settle and finish covering the trash and grasses, anyway..!! Improves traction and reduces power needed to pull the disc by a huge factor.. Duals are a very good investment for lose ground anyway.. I like to use one on the Landside when I plow, too.. Ron..
woodbutcher
01-25-2006 04:36:07
Clint,
I go along with RFH on the disk size. I have a 3010 LP, and I use a 10' HICO shredder, but my tractor would have a hard time with a similar size heavy-built shredder such as a Mohawk or Servis.
Butch
woodbutcher
01-25-2006 04:38:38
 Re: Equipment size for 3010 in reply to woodbutcher, 01-25-2006 04:36:07
Brian,
Pardon me...I was looking at the next question on the forum when I addressed you as Clint.
Butch
RFH
01-25-2006 04:10:27
As far as tillage goes, I guess it depends on what type of ground you're in. My 3020 diesel works pulling our 12' disk in freshly plowed ground. If your disks are good, which I'm assuming they're not if you bought it for 100 bucks, then it might be borderline too big for a 3010 gas. I pull 4x14s with the 3020 pretty good. I'd definitely go no bigger than that for a 3010, depending on tire condition, ballast, etc.
Brian Setlak
01-25-2006 05:28:44
 Re: Equipment size for 3010 in reply to RFH, 01-25-2006 04:10:27
Thanks for the quick replys guys. The disc is in great shape, needed on bearing but other than that it's near perfect. As far a my ground, I'd say it light to sandy.
Thanks
CMB
01-25-2006 06:26:42
 Re: Equipment size for 3010 in reply to Brian Setlak, 01-25-2006 05:28:44
In light/sandy soil, if your 3010 is "up to snuff"(55-58HP) you should be able to run in 4th or 5th gear with NO trouble at all. We pulled a 19'2" JD "BW" disc for many yrs, in heavy Iowa "Clarion Webster" soil with a 4010D(84HP) in 5th gear with no problems.
