Fan shaft repair
bubsdad
01-24-2006 19:38:54
The fan on my B is siezed to the shaft and will not turn or slip.
I had it in a press at work today and the only thing I could get to move on the shaft is the pulley. How do you get the giant valve keepers out of the end of that shaft if the collar that they lock into won't move.
Thanks for any ideas.
Mike M
01-25-2006 06:57:04
 Re: Fan shaft repair in reply to bubsdad, 01-24-2006 19:38:54
With the shaft assy. in a vert. up position and the bottom of shaft/gear resting on a block of wood. Get a pipe or bushing or something round just big enough inside to clear the keepers and still drive on the collar. Then beat it down until you can get the keepers off. Then clean it up and then you may need a gear puller to pull it off. Alot of times you end up needing new alum. drive plates and fibre disks but can save the rest. Your favorite brand of penetrant and maybe even some heat may also help.
P Browning
01-25-2006 05:41:07
From the service manaul we have - - - With fan shaft in vertical position and using a bar or press; force fan and drive discs into front bearing housing, and remove the two split cone locks and keeper from front of shaft. From front of tube, withdraw (remove) drive discs, friction washers, fan and front bearing parts.
An alternate method that works for JD H fan shaft disassembly - - - With fan shaft in vertical position (fan up), jam fan shaft S/A down onto a wooden block, forcing fan down into front bearing. Remove the two split cone locks, and the fan.
Bruce L
01-24-2006 23:05:11
I had similar trouble on a JD50. If it is like the 50 with a splined shaft, then you have to compress the spring by pushing the whole fan clutch assembly down the shaft. Then the keepers can come out. The splines are probably worn, corroded and dirty making it hard to move the fan-clutch assembly. You might be able to use a drill press to push the fan clutch assembly down the splines if you don't have another suitible press. I used the cross feed table and vise on a milling machine and butted the other end of the shaft up against an adjacent wall. Then with pressure from the cross feed, penetrating oil and some tapping on the fan-clutch, I eventually got the whole business slid down the shaft far enough to get those keepers out. But I had to work at it for a while. You don't want to do any serious pounding on the end of the shaft because it is easy to end up with a mushroom effect. And once the keepers are out, everything has to slide off there. The press set up isn't quite ideal because you can't center on the shaft. You have to press just to the side of center on the fan-clutch assembly. It works quite adequately when the parts are fresh and clean. Then all you are working against is the spring. Hope this helps. Your B is probably similar to my manual steering JD 50.
