4010 carb
R Fink
01-24-2006 16:10:50
have a 4010 with a MS carb wonder if a zenith would perform better and would a carb from a 105 combine be the same thanks
Mike M
01-25-2006 05:28:05
 Re: 4010 carb in reply to R Fink, 01-24-2006 16:10:50
I am not familar with the 105.
If it looks like the Zenith used on the 3010-4020 and you can get it cheap I'd try it. I was lucky to find one cheap off of a 3010 ? It had an adjustable load screw I think home made by someone instead of the soleniod shut off. Dispite my 4020 calling for a different number it works fine.
Glen in TX
01-24-2006 17:08:04
Might also use a 4030 carb if bolt pattern is the same or make it fit. 4030 gas originally used a MS TSX-969L or Zenith replacement 14997. The 14997 is still made by Zenith but only recommended for the 4030 so I don't know if it will fit? The Zenith 14990 I mentioned earlier is no longer made new by Zenith but most parts are available. The MS TSX is a good carb and parts are available for it so not all MS carbs are junk. Zenith tells me they do not make the new aftermarket carbs you see for 3010-4020 and tell us they no longer supply a carb to replace them new so don't know who makes those.
Glen in TX
01-24-2006 16:31:33
The later Zenith replacement for the MS USX carb used on 3010 & 4010 is Zenith 14990 and later gas 105 combine showed to use a Zenith 13023 replaced by the 14990 which was used on later 4020 also. Yes, it will run better with a Zenith if new or properly rebuilt and the MS parts are not all available now.
Erik in WI
01-24-2006 16:25:34
The MS carbs are junk. I have on on my 4020. Just had it rebuilt, the tractor ran better before. DON"T buy the new style Zenith, they are not the same as the old ones, and are nothing but trouble. I don"t know about the carb off of the 105. Try the bone yards in your area, they might know
