A high performance magneto
potentpuller
01-24-2006 15:21:52
Has anyone put a Magneeders Super Spark mag on their pulling tractor? If so, howd it run?
The Potent Puller
John T
01-25-2006 07:08:46
 Re: A high performance magneto in reply to potentpuller, 01-24-2006 15:21:52
Puller, I underststand those high performance Mags produce a higher energy spark then the stock ones for sure, but never owend one to speak with any experience. But, if the tractor had a battery and you ran at high compression, I think I would use an electronic ignition switch coupled with a high voltage high energy coil. One disadvanatge of a mag is the faster they turn the more energy they develop (and less energy as RPM decreases), but near the end of a pull when the RPM is at its lowest and youre really lugging down and a strong spark is needed the most, thats when it would be developing its LEAST energy. However, if using a battery powered coil ignition (stock or electronic) it would still be producing as much spark energy at low RPM as at high RPM.
Im NOT saying those hot mags are bad, Im sure they are good and develop more energy then a stock unit, but the engineering fact remains the slower they are turning the less energy they can develop which is a problem thats not there in a battery powered coil ignition. As compressions rise it takes more voltage to arc jump current across a plugs gap, which is why you see so many high energy electronic ignitions coupled with high voltage coils in high compression pulling tractors.
I still guess it would require a dyno so one could measure HP outputs with a high performance mag versus an electronic ignition, but if youre running at extreme high compressions and lugged down to real low RPM's, my bet would be on the electronic to produce more HP then the Mag.
Best wishes, hope someone with actual hot mag versus electronic ignition weighs in, and although Im sure the mags are fine, I still think the coil ignition would yield more HP if placed on a dyno under heavy load at low RPM!!!!! !!!
God Bless yall
John T
