420 T
WES STORM
01-24-2006 14:46:47
What would be the correct plow for a 1957 JD 420 T with a single front wheel? Looking for a 2 X 14" mounted type. What would be the model number?
Thanks
Wes
Glen in TX
01-25-2006 15:47:48
 Re: 420 T in reply to WES STORM, 01-24-2006 14:46:47
Wes, The JD 411 one bottom and 412 two bottom plows were also recommended for the JD 40 tractor and would work. The 411 and 412 were not really convertible like the 415 & 416 and no landing lever attachment either. Some other 3 pt. models that were made later during the 60s for 10 series tractors were the F35 and F45 in 2,3 & 4 bottom and F110 and F120 with boxed channel beam across the top in 2,3,4,& 5 bottom.
Glen in TX
01-24-2006 15:08:57
The JD 415 is a 2 bottom 3 point that could have came with 12" or 14" bottoms. I have a couple manuals that show the 415 2 bottom and 416 3 bottom were recommended on the 40 & 420 wheeled tractors. 415 and 416 could be converted either way to 2 or 3 bottom by changing frames and bolts. Operators manual old # OMA53156 covers both 415 & 416 and gives detailed setup and conversion instructions. Newer # OMA53158 operators manual and parts catalog PC459 covers 415, 415A, 416, & 416A.
WES STORM
01-24-2006 18:52:50
 Re: 420 T in reply to Glen in TX, 01-24-2006 15:08:57
Glen, Thanks for information. Is also called a Dubique plow?
Thanks Wes
Glen in TX
01-24-2006 21:14:05
 Re: 420 T in reply to WES STORM, 01-24-2006 18:52:50
Forgot to look and see if I had manuals on other plows that would work also. There are some other JD 1,2, & 3 bottom plows that should work behind it too.
Glen in TX
01-24-2006 21:03:53
Wes, On the cover and inside the OMA53156 I have it says nothing about Duburque but just says: John Deere Integral Tractor Plows, Two and Three Bottom, Nos. 415 & 416 for John Deere 40 & 420 tractors. These plows have a standard catagory 1 three point hitch that will fit other tractors as well. I think I have posted pics of these before over on Implement Photos section. Do a search there and some pics of these plows should show up. I have a extra copy of manual if you want one or need pics email me. Both are water stained but legible and full of good info showing instructions, attachments and top link adjusment and wheel settings for 40 & 420 Standard, Utility, Tricycle and Two-Row Utility tractors for the plows. No parts listing in the back like some old manuals have though.
WES STORM
01-25-2006 18:12:08
 Re: 420 T in reply to Glen in TX, 01-24-2006 21:03:53
Glen, I sent you a email.
Thanks Wes
