GOVERNER MODEL 50
STEVE PHELPS
01-24-2006 12:04:16
MODEL 50 WAS RUNNING GREAT UNTIL THIS WEEKEND MOVING SNOW. AS I PUSHED FOWARD ON MY THROTTLE LEVER LIKE NORMAL,THE ENGINE SPEED JUMPED TO A VERY FAST IDLE.I KILLED ENGINE AND CHECKED LINKAGE EVERYTHING LOOKED OK.RESTARTED ENGINE ALL I HAVE IS LOW IDLE OR VERY WIDE OPEN THROTTLE.SEEMS THE GOVERNER IS NOT WORKING.WERE DO I START ? THE FLAT SPRING ON GOV ARM IS OK. IS THIS AN INTERNAL PROBLEM? I'M LOOKING AT A BREAK DOWN PICTURE FROM JD.
Carl NY
01-24-2006 14:43:07
 Re: GOVERNER MODEL 50 in reply to STEVE PHELPS, 01-24-2006 12:04:16
Sounds like a govener weight has come off the hanger assembly. Pull the end cap & look inside. You should be able to see if a weight is loose.
STEVE PHELPS
01-24-2006 16:39:41
 Re: GOVERNER MODEL 50 in reply to Carl NY, 01-24-2006 14:43:07
THANKS I WILL TRY THAT TONIGHT
Mike M
01-25-2006 07:02:33
 Re: GOVERNER MODEL 50 in reply to STEVE PHELPS, 01-24-2006 16:39:41
If you pull that LH. Gov. cover off before you try to put it back on it's always a good idea to pull off the dist. or mag. because the shaft is spring loaded and when drawing up the bolts if the coupler doesn't line up exactly you can break stuff.
Carl NY
01-24-2006 14:34:03
