4020 Problem
Jason_501
01-24-2006 11:26:57
My 4020 Diesel Runs rough for about 20 seconds when you start it cold. After it warms up it runs smooth. After running just a minute and shutting it down, it starts up fine. Only when it is cold does it run rough (temp is about 50 deg. outside) Sometimes it will die the first time or two you try to start it. I have bleed all the lines for air. Changed the fuel filters. What do I do next? Also another problem is the steering doesn't work for the first 30 seconds or so. After that it is fine. Not sure what to look for on that.
thanks
John in Md.
01-24-2006 16:37:37
 Re: 4020 Problem in reply to Jason_501, 01-24-2006 11:26:57
Get a good diesel repair shop to test your injecters, sounds like one is getting worn and you're not getting a good spray pattern.
When you first start does the three point lift or is it slow also? If both are slow check your filter. If the hitch is smooth you may have air in steering line and have to bleed it (refer to shop manual). When you start are you sitting with your foot down on the clutch? If you are try not depressing the clutch and see what happens.
