JD 219cu engine - water in antifreeze
Dan C.
01-24-2006 11:20:05
Pulled the rad. cap off to check antifreeze level - found oil floating on top. Drained the coolent system down and flushed. I found no traces in the oil after draining oil. I am in the process of still flushing out the rad. and enging block.
I did find that my rad. cap has a bad gaskit thus the coolent system is not under normal pressure when up to temp. Maybe this could effect why there might not be water in the oil pan. I am going to get a new cap this weekend to test.
It seems this is not a major water/oil leak but a small one. Any ideas on how to find out where this leak might be? It looks like I have a HYD oil cooler and no oil cooler so I don't think I have a oil cooler problem. I have read about pressure testing the coolent system with the oil pan off but since I am not getting any oil in the pan not sure what to do ? ANy advice will be of great help.
Thanks.
Dan
WTW
01-24-2006 12:42:42
 Re: JD 219cu engine - water in antifreeze in reply to Dan C., 01-24-2006 11:20:05
Dan, The key thing you have to consider here is: There is oil in the coolant / radiator verses coolant in the oil / pan. This scenario tells me your problem is NOT liner related. It is telling me your problem is oil cooler or head gasket related. Good chance that your engine may not have an engine oil cooler on it and if it does not your problem is most likely head gasket. The reason it is not the liners packings leaking is because water / coolant pressure at liner packings is greater than atmospheric pressure in pan. If liner packing were the cause you would have coolant in your oil pan. For oil to be in radiator the leak has to be in an area where oil pressure is greater than coolant pressure which leaves the oil cooler or head gasket. To remove oil from the radiator draining and flushing it is a hard and difficult way to do it. The simple way to remove this small amount of oil that you are seeing in the radiator is: Simply over fill radiator causing oil to over flow out top of radiator. Oil will always come to the top of radiator and separate from the water ? coolant as water is heavier than oil. It will make a mess on top of hood but will rinse off with a hose. You will get the oil removed from the radiator ? cooling system faster this way than you will trying to drain it and flush it out because when you drain radiator the oil will just stay stuck to the many core tubes inside the radiator. Good Luck, DW.
Dan C.
01-25-2006 06:54:50
 Re: JD 219cu engine - water in antifreeze in reply to WTW, 01-24-2006 12:42:42
Thanks DW for the information. I too have conclued that it will more than likley be the head gaskit but it is nice to see another person think its that as well. The only thing I have left to test is the rad.cap has a peice of gasket missing - thus the coolent system is not normally being pressured up. SO I will replace the rad. cap and run the tractor a while and let the cooling system obtain normal operating pressure - I will check to see if any coolent will be present in the oil pan. Hopefully not and I am still only looking at a head gaskit which I should be able to do my self. Once again thanks for the info. FYI -I don't have a oil cooler.
buickanddeere
01-26-2006 15:12:01
 Re: JD 219cu engine - water in antifreeze in reply to Dan C., 01-25-2006 06:54:50
If the rad cap was missing the gasket then oxygen and carbon dioxide from the air would be entering the cooling system. A water based compound circulated at high temps over dissimilar metals is a sure recipe for corrosion.
