JD 4430 cab door
Craig Wooten
01-24-2006 08:27:41
I have asking this question again as I can't find where I posted it before. The cab door on my 4430 is worn so that it is difficult to close and hangs down visibly when closed. Is this a hinge problem, pin problem or both. Can the hinges be replaced if needed? Thanks, Craig Wooten
Craig Wooten
01-25-2006 20:32:58
 Re: JD 4430 cab door in reply to Craig Wooten, 01-24-2006 08:27:41
Thanks to all for your input. I appreciate it. Craig
Glen in TX
01-24-2006 14:50:12
Thought I saw someone has new aftermarket doors now and not sure what else they have and hinges too or not.
WTW
01-24-2006 12:54:15
Craig, The hinge halves on the door bolt to the door frame. The other half of hinge is welded to the cab frame. In the rare event you have to replace the hinge on the cab there is a service tool that John Deere dealers were all supplied with when Sound Guard bodies were introduced to hold hinges in correct position to weld them in place. Can be done with door to but is much easier with tool / jig. Good Luck, DW
G/MAN
01-24-2006 10:23:59
Half of the hinge bolts on, either to the door or the SGB, I can't remember which right off hand. The other half is welded to one or the other. Most commonly, the steel pins and plastic bushings get worn, so you may get off easy. But if the bushings are long gone, the pins might have worn into the hinges, requiring replacement of everything. Also, the pins can be a real bear to get pulled out, and the door is heavy, so make sure you have help handy when you start removing it. I doubt you want broken windows in addition to a sagging door.
