4020 hydralic bleed off
O'Neil
01-24-2006 07:38:36
I have a 72 model 4020 with syncro Trans and every time the tractor is shut off for 30 minutes or more you have to let it run about a minute before you can steer it or raise the lift or the remote cylinder. I've been told that there is a check valve somewhere that is sticking, Can someone help me with this? where is it located, if I need a new part, what is the part number? Thanks for your help.
Bob
01-24-2006 08:41:30
 Re: 4020 hydralic bleed off in reply to O'Neil, 01-24-2006 07:38:36
The older 4020's had a check valve in the transmission case, below the transmission pump outlet steel line.
That MAY be what you have been told about.
AFAIK, when the re-designed units came along, after serial # 200999, (which would include yours), the check valve in the main case was eliminated. I can't recall if there is a check valve that serves the same purpose in the valve assembly mounted on the side of the tranny case, ahead of the LH final drive.
