Did JD ever make a 4wd gas tractor?
Neilho
01-24-2006 04:24:16
I'm happy with my 420W but need a tractor with more traction and power to work in the woods, plow snow and run a 5' brushhog with some authority. I seem to be allergic to diesels and diesel fuel and like the cold weather starting capability of gas, too. So before I start looking at heretic brands, did John Deere ever make such a beast?
TIA,
Neil
Mike M
01-25-2006 05:41:46
 Re: Did JD ever make a 4wd gas tractor? in reply to Neilho, 01-24-2006 04:24:16
I was thinking of some options ?
It may get expensive,but it may be possible to buy a later JD 4wd utilty tractor. Then you could sell off the diesel and put in a gas engine from an older utilty model ?
If one was to buy two tractors and do the swapping work himself then resell the diesel one it may not end up too bad $$ wise ???
neilho
01-26-2006 03:28:40
 Re: Did JD ever make a 4wd gas tractor? in reply to Mike M, 01-25-2006 05:41:46
Now there's a good idea. I'm not familiar enough with JDs to know what gasoline engines would interchange with the diesels. Anybody out there know? I s'pose a tractor with a bum diesel engine could be had pretty reasonably. Or perhaps a diesel could be converted to gas. Now that would take some changes. Manifold and carb swap, distributor and sparkplug installation, compression change. Not to mention whether the camshaft would even be appropriate. The bottom end should hold up just fine, though! Straying a bit from the original subject....
neil
Mike M
01-26-2006 04:38:59
 Re: Did JD ever make a 4wd gas tractor? in reply to neilho, 01-26-2006 03:28:40
You might try reposting a new question as I'm not real familar with these newer ones either. I can't remember when 4 wd started appearing ? Maybe with the later 40 series I know my uncle had a 2940 with it. I would think that a smaller model with a 4 cyl. engine might swap out with say a model 2020 which there are gas models around. If you would make the swap with 2 good running tractors the one with the diesel should resell pretty good.Or you may just advertise and sell your diesel engine outright and you should be able to find a gasser at a salvage yard.
Anyhow something to think about for sure ?
Big M
01-24-2006 18:51:52
Would you want a MM 706LP with power front? E-mail back for a phone number of one for sale in KS. There were not many of those made.
neilho
01-24-2006 13:36:15
Thanks for the replies, guys. Sounds like a 4wd gas tractor is scarcer"n hen"s teeth. Hydraulic assist is a phrase I haven"t heard before. What does it mean? I used a Kubota diesel excavator for a day this summer and will have to say that it wasn"t too bad to breathe. Wintertime ease of starting is an issue, too and I don"t really want to set up another fuel supply system- all my other equipment is gas powered so my desire for a gas tractor isn"t entirely based on my weak stomach. One of the local excavators sold a JD 350 gas dozer a couple years ago and it went pretty reasonable, too. I think they"re better suited for pushing dirt than for my application.
buickanddeere
01-24-2006 12:35:07
There may have been a hydraulic assist gasser 4020 or two leave the factory but I've never seen or heard of one. Imagine owning a 1972 LP console hydraulic assist 4020 with every option?
billde
01-24-2006 09:12:23
Neil, back in the 60's Oliver made a few small front wheel assist tractors as well as larger ones. M&M made front wheel assist as well as IH in gas but they were larger tractors in the 70 to 90 hp class. The problem will be that not a lot were sold so the price will be high. If you are real serious drop me an email and I'll try to get some model numbers.
Mike M
01-24-2006 05:18:53
If your working in the woods alot JD did sell several models of gas engine crawlers. I've even seen some of the ones as late as a 350 model advertised with gas engines. 4wd really only became popular after the extinction of gas engines in farm machines.
Have you driven any of the NEW diesels lately ? They burn alot cleaner than they used to.
Leroy
01-24-2006 06:24:19
 Re: Did JD ever make a 4wd gas tractor? in reply to Mike M, 01-24-2006 05:18:53
The fuel is still the fuel no mater what engine it goes thru or if it is coming out of the pump. The station I get most of my gas from, 6 tanks a week, has one set of pumps with a deisel hose and the smell of that deisel bothers me if I pump gas there, and I have turned green from driving a neighbors deisel so I want nothing to do with them
