1240 Planter Opinions
JD2120
01-23-2006 21:07:41
I've found a good looking 1240 JD plateless planter for sale for $200. Guy didn't know anything about it and i was leary of buying it since i didn't know anything myself. I would like to have a 7000 planter but they are out of my price range. Do the 1240's raise up and down by a hydralic cylinder? Are they a fairly simple design, easy to fix? I like the plateless idea cause i plant different kinds of veggies and it would come in handy, how could i tell if it works ok without putting it in the field?? Kinda hard to do this time of year, and he didnt have a field to plant in either. Any help you could give me i would appreciate.
HappyHank
01-23-2006 22:23:53
 Re: 1240 Planter Opinions in reply to JD2120, 01-23-2006 21:07:41
I used to own a 1260 (6 row) JD planter that was like the one you're looking at. It was a runner type planter, not a disc opening type, and the units were kind of prone to needing some repair. The units use a finger pickup for corn that run on a cam . The fingers are spring loaded and corn treatment would often corrode these springs and fingers a little and needed upkeep every year to operate right. The seed pickup units then deposited the seed onto a rubber belt with paddles that would rotate vertically and drop the seed into the ground. Kinda hard to explain in words. Mice liked to chew up these rubber belts. We would take the units off after planting was done and keep in an old refrigerator to prevent this. The bean unit (slide a lever to open up a new hole in the seed tank bottom) would drop beans into a bean cup that would deliver them to the ground. Worked OK but there were some chains that had to be moved and such to switch crops. If I were lokking to buy one, I'd pull off a couple of seed units and look at their condition to determine worth of the planter. If they are rusted badly, it may take a lot of work and parts to recondition. The seed units are under the seed hoppers on each row. 4 on the one you're looking at. I think you might take a large Crescent wrench and turn the driven shaft and see if the units will even turn. I used this planter for several years and, at that time, they were a fairly good planter. Good bean planter. I would'nt want t give over $200 for a good running 1240. Much less if row units need rebuilt. JMO
