1941 H john deere Electril
Russell Cheever
01-22-2006 17:06:15
Can any help with an electril diagram for a 41 H JD, generator, cut out light switch hook up?
John T
01-22-2006 17:23:06
 Re: 1941 H john deere Electril in reply to Russell Cheevers, 01-22-2006 17:06:15
Russell, if its really??? a generator that uses a 2 wire Cutout Relay and the combo light switch & field current control instead of the full fledged 3 wire Voltage Regulator, it wires as follows:
BAT terminal of Cutout Relay wires up to the load (NOT to battery/starter) side of ammeter. 12 gauge wire will suffice. The load side of the ammeter also feeds the BAT input terminal on the light switch to supply its voltage which runs the lights when ON. Wires from the light switch feed the lights.
The other supply side of the ammeter (has but one wire) is fed from the hot ungrounded battery post, usually via a 12 gauge wire to where the big battery cable connects to the starter switch.
GEN (or ARM) other side of Cutout Relay wires to the Generators Arm post. 12 Gauge wire will suffice.
Field post on Generator wires up to the Gen or Fld terminal on the light switch where it gets a dead ground for low charge or through the light switch resistor for low charge. 14 gauge would suffice.
The light switch needs a good ground connection.
Once wired up I would polarize the genny.
John T
Russell Cheevers
01-23-2006 17:24:59
 Re: 1941 H john deere Electril in reply to John T, 01-22-2006 17:23:06
Thank you for the info John.
