116W Anyone
Mixman
01-22-2006 17:05:11
I have a 116W JD baler I still bale wheat straw with. I think I am needing the kinker,cutter shafts. It started acting up at the end of last year. This is more of a novelty than anything but I want to keep it in working condition. Can anyone tell me where there might be parts.
430WLPG
01-23-2006 17:20:41
 Re: 116W Anyone in reply to Mixman, 01-22-2006 17:05:11
Can you send parts numbers and pictures? I have a lot of parts for those, but I need a picture to look at.
Dale in IN
01-23-2006 12:49:13
Mixman:
There is a bolt on those knoters that holds them in place. I dont recall just where it is located for it has been over 20 years since I had a 114W which is the same baler only the chamber is 2" smaller one way. Once removed you can roll those knoters out where you can see the kinker and cutters. Those kinkers have a habbit of retaining a peice of wire in them. And after the 2nd or 3rd piece they will not let the wire into the proper position to tie. You will need to clean the wire peices out. I had this problem with the 114W. Try this and see if it helps.
Mixman
01-23-2006 16:27:50
 Re: 116W Anyone in reply to Dale in IN, 01-23-2006 12:49:13
I have the baler empty and there isn't any wire caught in the twister pinion. I have to go by what I have been told although I've had this baler for 25 years, that when the wire hangs up in the twister like that it is either rusty wire or worn twister pinions. If anyone has anything to add please do. I need all the help I can get.
Leroy
01-22-2006 18:13:57
Where do you even find wire for it??? It hasen't been avaible here in Ohio for several years. I have both an early and late version 116W baler. The first one when I bought it I tried balling a few bales with and the rusty wire broke and have never tried to rethread it and never tried to bale with the second, just have taken them to a few machinery shows. The bale loading shute was not designed by Deere but by Holdren Bros of West Liberty. Ohio and a few years ago I took it there and the one of the Holdren Brs. that were left and there service manager could not get over one still being in existance and both my balers had that wagon loading shute and hitch
short
06-17-2006 19:01:03
 Re: 116W Anyone in reply to Leroy, 01-22-2006 18:13:57
i have the small rolls for 116 114 balers im in sw ohio 513 area code
Mixman
01-22-2006 19:16:12
The wire for those was supplyed by Northwestern Steel and Wire in Rock Falls Ill. They are no longer. By chance a I found that there were a few boxes in a warehouse there and I got all they had left. Since then I was at a farm sale that had 2 boxes (enough for 1 fill) and bought them.($5.00) I let them soak in fuel oil for a year and they worked fine
