Getting hubs off ( long post )
north east pull
01-22-2006 16:10:02
Let me start out with this is not my first time of getting hubs off of a tractor. I am working on a 1949 John Deere G I have been at this now 4 weeks now and during the week have consumed 1 can of Kroll and am on my second can of PB blaster and some other good name brands followed by taping with a 5 LBS hammer .
I made a 4 inch U channel puller ( 2 welded back to back with center bolt and 5/8/ rerode to the rims 18 inches apart .) Results egg shaped washers.
Made up 4 inch square x � inch washers Results are stretched rerode like an hour glass. And flexed U chanel.
New rerode .
Results pulled thread on the rerode and out of the nuts .
Made new puller . ( 1 inch thick plate drilled holes to put 3 7/8 rodes in to hub where hub bolts go . Made center stud on plate for 10 ton porta power ram..
Results bent porta power handle .
Keeping in mined I have heated this with a big rose bud torch 5 or 6 times during this time frame. I have tried an old wife�s tail of melting in Paraffin wax to break the rust and lubricate it.
New puller # 3 10 ton air over Hydraulic this time . mixed with 18 LBS 6 foot slide hammer trying to push hub in then out .
Results broken slide hammer foot. ( exploded in to 3 pieces ). And 1 Really sore back.
Next weekend I will try driving tractor working breaks to break loose hub if that does not work the only thing left that I know of is. A. squeeze shop cat to Pee on it.
B. Have 3 or 4 Barley pops and then set on fire rolling it down A big hill towards a pond .
Unless you folks have other suggestions in mind for me to try.
Thanks, for any help Northeast puller
Kris A NC
01-23-2006 17:28:47
 Re: Getting hubs off ( long post ) in reply to north east puller, 01-22-2006 16:10:02
I have the same exact problem with my "51B. I have been driving around for a month with the collar off. I used a 12 ton jack on it and heat and PB blaster and nothing so far...Kinda frustrating, but I am going to try some of the suggestions here that I didn"t try. Hopefully that will help. Good luck to you...I think we both will need it!!!
JDBert
01-23-2006 07:33:23
Unbolt the cast from the center hub and work with it that way. That cast wheel keeps the hub tight as well.
CMB
01-23-2006 05:38:36
Some move really hard. Saw a one that took 50 tons in a press & a lot of heat to start! When it did break free, sounded like a rifle shot!
Dave NE IA
01-22-2006 19:15:55
If you have another tractor you can tie them wheel to wheel with three or four log chains and drive them along side each other. That gives them a pretty hard jar and does not take anything from your back either. Keep a close eye on it so when it comes loose you do not run it off the axle. Dave NE IA
RalphinWI
01-22-2006 17:09:02
Warning! I have probably never dealt with one that spent a lot of time sleeping under the stars. Jack and block tractor so the wheel is off from the ground. Then I grab my log chain (5/16 or 3/8), feed the narrow locking hook out through the hole for wheel weight and back in through the one directly opposite, then back to the remaining chain and hook it leaving enough slack to slip the hydralic jack (and a 2x4 to cushion the base)in (top end toward and centered on the axle). Align and tension the jack. You already have it soaked in PB so get your rosebud out and heat it, while hot give it a dose of PB. If there are any pores it will pull the PB in as it cools. Tension the jack and pound on the side of the tire with a rubber mallet or sledge. The idea is to get the wheel to vibrate. If the tire is setting on the ground the vibrations are damped out very quickly. If the tire is filled with fluid it will also damp out those vibrations. Or use a mushroom tip in an air hammer on the casting. Patience usually works better than brute force. The fill hole of the jack needs to be on top when the jack is used in a horizontal position.
RalphinWI
01-22-2006 21:07:54
 Re: Getting hubs off ( long post ) in reply to RalphinWI, 01-22-2006 17:09:02
I forgot - Pounding on the sidewall or edge of the tread at the top or bottom of the tire when the plane of the chain is horizontal will give the most vibration.
Eli
01-22-2006 16:25:03
If it was mine and it has the removeable hub for cast wheel, cut it into three pieces. Its only a small cut at the edge of each slot.If you use a thin blade you will not be able to tell, and the hub will tighten tighter to the axel. The 6 bolts will hold the three pieces with no problem. Old farmer taught me this. I still use my tractors, and adjust the wheels often. Wouldn't do this on pressed steel wheel hub. Good luck, Eli
Mike M
01-22-2006 16:20:41
You must really have some rusted on hubs !
The toughest one I had so far were a set on an unstyled B that sat out for many years. Had to hook a large OTC bar type puller on it,heat the hubs and at the same time had to cool the axles with a water hose.
Go out and try to drive around or even better hook a plow to it maybe something will jar loose.
Hal
01-22-2006 16:20:40
I removed mine today similar to your 1" plate with the portapower attempt, I just put nuts on the allthread and let the 1" plate rest against the end of the axle and tightened the nuts alittle at a time and it came right off I read back in archives and Easy had tried the same thing you did and it didnt work, but tightening the nuts on the allthread did work for him as well
Mike from Cny
01-22-2006 16:48:52
 Re: Getting hubs off ( long post ) in reply to Hal, 01-22-2006 16:20:40
I had this problem on my 43' A that has the non removable center piece that goes on the axle it self. My boss bought one of those $175 wheel pullers advertised in green magazine. It didnt do anything TILL I soaked the crap out of it and cranked the puller down real tight, drove around the yard with the puller still on real tight and both sides loosened up fairly easy, and they were covered in rust. Thats what worked for me. if that doesnt help, try driving it tight cirles with 1 brake locked up.
