G HIGH COMPRESSION PISTONS
HAL
01-22-2006 16:08:45
I have found a set of high compression pistons and block bored .125 over, are there any concerns running this set up with a factory 1951 head and all fuel manifold? I am not trying to build a puller or anything but my block is bad and I am going to have to do something, and didnt want to buy the hi-comp stuff only to find out I was going to end up with alot of extra expense or problems.
JDG
01-22-2006 20:55:29
 Re: G HIGH COMPRESSION PISTONS in reply to HAL , 01-22-2006 16:08:45
That set up will work fine. You will need a good clean cooling system or it may want to over heat if you work it hard.
