Gearing down my G
sean t
01-22-2006 15:27:34
I need to gear down my 47 G, anyone know how or where i can find lower gears that will fit? I'm going to be doing dead weight pulls, and need more torque. Any other ideas would help.
gpop
01-23-2006 04:28:21
 Re: Gearing down my G in reply to sean t, 01-22-2006 15:27:34
a first reduction gear and clutch gear off of a 70 deisel without live power will slow it down some.
buickanddeere
01-22-2006 17:03:43
I wonder..... ..... .Deere like to use the same parts and production line equipment as possible on several models to reduce cost. I wonder if maybe another tractor used the same diff and axle splines and they are mounted the same distance apart/centerline as another model. However the gear ratio is different. I have a set of late 1010 final drive gears that someday will get swapped into the 435.They will run about 15% slower. The 520/530 use a slower final ratio than the B/50 if memory serves correctly?
