HARD STARTING B
Bill Dorrance
01-22-2006 09:07:19
MY B HAS BEEN HARD TO START, IT IS A HAND CRANK AND IT SEEMED LIKE YOU COULD NOT EVEN FLOOD IT WITH THE CHOKE ON. I DECIDED IT MUST BE DRAWING AIR SOMEWHERE OTHER THAN THE CARB AND IT MUST BE LEAKING BY THE MANIFOLD GAKSET. WHEN I GOT THE MANIFOLD OFF I COVERED THE INTAKE PORT WITH THE PALM OF MY HAND AND ROLLED THE ENGINE OVER. I WOULD SUCK ON THE INTAKE STROKE AND THEN I COULD FEEL PRESSURE AS I CONTINUED TO ROLL THE ENGINE OVER. SO I PULLED THE HEAD AND GROUND THE VALVES. THE MANIFOLD AND HEAD WERE VERY CARBONED UP AND SOME CARBON WAS UNDER ONE OF THE INTAKE VAVLES. PROBLEM SOLVED?
NO, I PUT THE HEAD BACK ON LAST NIGHT AND AS YOU ROLL THE ENGINE OVER I CAN STILL FEEL PRESSURE BLOWING BACK OUT THE INTAKE PORT ON THE HEAD. IT DOES DRAW VERY GOOD ON THE INTAKE STROKE, BUT I WONDER HOW THIS CAN BE RIGHT?
WHEN THE TRACTOR STARTED IT RAN WELL BEFOREE, MAYBE THIS IS NORMAL.
ANYBODY RUN INTO THIS BEFORE? IS IT NORMAL??
BUBSDAD
01-24-2006 19:34:23
 Re: HARD STARTING B in reply to Bill Dorrance, 01-22-2006 09:07:19
What I mean by hard starting is you can crank it with the choke on for 10 minutes or until you have a heart attack and no fuel ever comes out of the compression releases. this thing just wont draw a fuel mixture from the carb. I have checked the fuel flow at the carb and it is great. I have switched carbs with another B that starts great and it still will not get any fuel.
I have not started it since replacing the head and manifold gaskets because I decided to fix the frozen fan. I hope it is fixed.
buckeye al
01-23-2006 14:09:19
What you're feeling is normal valve operation and cam duration.
At the running speed of the engine, there is an optimum point at which the valve must close to trap the most of the fuel mix possible that has entered the combustion chamber. That time is NOT when the piston is at BDC! The piston can start the compression stroke while the intake valve is still open because still more fuel is entering the chamber even though the piston is moving towards the head. This is because the intake phase of the cycle all takes place in a vaccuum.
The engineers tried to specify a camshaft grind that closes the intake valve at the moment the flow of fuel INTO the chamber would stop because of the advancing piston when the engine is RUNNING under average conditions.
You do not experience that condition at the hand cranking speed because the fuel mix (in this case just air) easily has time to completely fill the chamber because the engine is moving VERY slowly when compared to the speed of the running engine. If the valve closed at BDC, the engine would be robbed of power for lack of ability to intake the maximum volume of fuel mix.
Hope that helps make sense of what you feel there.
bm3501466
01-22-2006 15:34:01
My B after I fixed the carb, will start in 2 cranks, one with the choke, and then one at half choke. I found that the spring at the very bottom that holds up that jet was missing and the load screw was being covered up. After I fixed that fuel would always come out of the petcocks. Before that it wouldn't always.
Mike M
01-22-2006 12:21:00
It could be that some oil or assembly lube in on the valve face letting it not seat ? I had this happen before. I took a soft faced hammer (dead blow)and taped on the valve stems and then they seated.
old
01-22-2006 09:23:06
Please take off the cap lock, on one likes to be yelled at. But yep its normall to have a suck/blow on any engine as far as intake. Now you say hard to start, how many turn of the flywheel does it take. My B takes from 4-10 to start it depending on the weather etc. What I do is choke it for one full tunr of the flywheel, then un choke it and most of the time it will try a couple times and the hit and start after 4-7 turns unless its cold out.
