4030 Quad Range Problem
Charles A. Durb
01-22-2006 06:59:56
I have a J.D. 4030 tractor with a Quad Range transmission. The speed shifter will not engage in range 3or4 with the clutch pressed fully in. It makes no difference what letter range it is in, ABCorD. It seams to engage in 3or4 but will not stay and grinds when releasing the clutch.
Is this a major transmission problem or a linkage problem?
donmyeil
01-22-2006 07:14:02
 Re: 4030 Quad Range Problem in reply to Charles A. Durbin, 01-22-2006 06:59:56
First I would make sure the adjustments are correct. However I would suspect the highside syncronisers and shifter are worn out. This requires a split and rebuild of the top syncroniser shaft.
