Electicial issues on an A
Elk Hunter
01-22-2006 06:04:21
I'm not too familiar with normally open or closed contacts. I rewired my A, had the generator rebuilt because it showed an irregular volt reading, installed new points, condenser, cap and rotor, checked timeing. This bird still won't start. Have fire to the plugs, gas to the cyls. If the ignition switch is bad or stuck would this cause a no start. According to the wiring diagram this would not be the case? Also, when I hooked the wires back up to the generator I get sparking, indicating a short somewhere. Could that be a different issue all together? Oh yea, I do get some minor back firing, and I did put new plugs in. Any thoughts? -Tom
01-22-2006 23:53:25
 Re: Electicial issues on an A in reply to Elk Hunter, 01-22-2006 06:04:21
Had the same problem, you can have a rusty carb and get gas but not run,if you get a good back fire, you may have the plug wires back wards, a rusty carb. will sneek up on ya, I cleand mine with water,soda and lime, and batt.charger. good luck -�-
Thomas Donahy
01-22-2006 11:40:15
Dear Mr. Elk Hunter, Are your spark plugs wet or dry? If they are dry either the internal passages in the carburetor are plugged or the choke is not closing. If they are wet there are several possibilities. The choke could be stuck on, the air cleaner could be plugged or the plugs are fuel or carbon fouled. I would unhook the air cleaner at the carburetor. This will allow you to visually inspect choke operation and at the same time eliminate the possibility of a plugged air cleaner. Next I would check timing.
John T
01-22-2006 07:39:19
Hunter, If you remove the plugs, have the wires attached but the plugs sides grounded to frame, turn her on n crank her over, are both plugs producing good visible blue sparks??? If so the switch must be providing voltage to the coil. If theres any doubt to the switches condition, by pass it and hot wire the coil direct by running a hot 12 volt feed direct to the coils input (NOT to distributor) terminal and see how the spark looks when shes hot wired??? If still the same I doubt the switch is the problem but it wont hurt to try n hot wire the coil anyway to see if it makes any difference. Im guessing this is a batery powered coil ignition right??? If its a mag all the ignition switch does is short it out when OFF so dont do any such hot wire test above just be sure the mags terminal isnt grounded or connected DO NOT PUT VOLTAGE on a mags terminal, they just use a ground to kill the spark when OFF.
If the plugs arent firing, post back and tell me what ignition you have and I will provide more tips !!!!! !!!! You can remove the coil wire from the distributor cap (leave coil end intact) and place its bare end to within 1/8 from tractor steel, turn her on n crank her over a a good blue spark ought to be jumping that gap. If so there but NOT the plugs, its a plug or plug wire or a cap or rotor problem. If the coil wire isnt even firing, let me know and I will tell ya how to test more things.
If shes got a good spark and its in time and the right plug wires are on the right plugs????? ? are they??? If not it may pop n bang n backfire something awful. The left cylinder fires first at TDC then 180 degrees later the right cylinder fires on its TDC, are you sure its wired correct???
If the pugs fire AND AT THE RIGHT TIME I would look at fuel issues next. Does it have fresh clean water free gas??? Is the air cleaners lower bowl okay and not full of water??? Is the choke butterfly plate actually closing when the rod is pulled??? When trying to start and usign choke is there any smoke or vapor coming out the stack??? If not I wonder if shes getting fuel??? If you remove the plugs after a starting attempt are the plugs bone dry (not enough fuel) or wet (may be flooded)
If she hasnt ran in a while you may try to remove the plugs and squirt some oil in the cylinders n try her again or if you can try a pull start it will get the rings n cylinders oiled up so try that n see if she runs??
There shouldt be a spark when you attach the wire from the ammeter to the VR's BAT terminal cuz the cutout relay should be in its normally open state, but I have seen them make some small spark on initial hooks up but then be fine afterwards. Even if shes not charging so long as the coil is gettign full voltage that shouldnt stop her from firing.
Play with the carb n fuel n choking some or oiling or a pull start and see if the plugs are firing and post back. If the plugs had been fouled or carboned up, try a different set.
Let us know
John T
Elk Hunter
01-22-2006 08:40:25
 Re: Electicial issues on an A in reply to John T, 01-22-2006 07:39:19
John T. Thanks for all the tips. Let me give you some more details. I have a distributer. I have the hot spark at the plugs, also I did the coil test with the wire 1/8th from the frame and got a great spark. When I try to pull start or use the starter I get some black puffs of smoke then it goes to grey, I guess vapor as you described.
When I open the petcock on the carb bowl I got plenty of fuel, I just put fresh gas in the other day. She ran great about a month ago then I shut her down to put her away. Never started since???? Someone posted last week about maybe a LH cam bearing the A's had trouble with. It just seems like it should be something simple that I am overlooking since I am sort of new to the 2 cyl jd's. What is the liklyhood of wire mesh in the oil canister being clogged? The air intake is clear as a bell too. I am having a hard time beleiving it is a major motor issue but maybe I am dead wrong??? -Tom
John T
01-22-2006 08:50:22
 Re: Electicial issues on an A in reply to Elk Hunter, 01-22-2006 08:40:25
Its sounding more like maybe an excess fuel problem instead of an electrical problem. Yeppers, those air cleaner meshes can get clogged, maybe see what she does if you remove part of the air inlet piping so shes gettign plenty of air. It dont take too much raw fuel as indicated by black exhaust smoke to carbon soot foul the plugs you know. If thay have that flat black colored even sooty look they may not fire right.
I wonder about the carb bowls float level?? You may wanna remove the carb bowls lower drain cock plug and use some sort of hose barb attached to iw with a clear fuel line held above the bowl level to see just where the float n bowl level is running at. If its overflowing thats flooding the engine and gas fouling the plugs.
I guees try fresh clean plugs,,,,,insure no air cleaner restrictions,,,,, check the carb bowls float level,,,,, try a pull start and DO NOT overchoke her n see if she runs with NO EXCESS BLACK EXHAUST SMOKE. If she tends to black smoke and the plugs come out wet and wiht crabon soot I think its an exces fuel or air starvation problem. Make sure the choke butterfly plate is working and staying put relative to where the rod is set.
John T
