JD 4020 ENGINE KNOCK
DUG in TX
01-22-2006 04:58:55
I have started to hear a KNOCK in my 4020 diesel engine. It can only be heard at 1200rpms, Slowing the engine or speeding up, the KNOCK goes away. I had a buddy of mine tell me if I put a GOOD muffler on tractor the sound will go away. DON'T KNOW! Is it a possible injector not firing correctly, or could it be more. Engine has not lost any power. Smokes a little but always has. Any ideas?
Randy Varilek
01-26-2006 22:13:08
 Re: JD 4020 ENGINE KNOCK in reply to DUG in TX, 01-22-2006 04:58:55
My 4020 powershift developed a knock at low rpm (below 1500) last spring. got several ideas but they were all way off. one old salt told me to check the flywheel and sure enough the flywheel had come loose and broke the guide pins. might be worth checking.
Maark
01-22-2006 09:15:07
Take your pump connector off at the front of the engine and replace your plastic pump bushings. They will sound like a knock when they get loose. You might also want to replace belts while the pump drive is apart.
msb
01-22-2006 15:36:45
 Re: JD 4020 ENGINE KNOCK in reply to Maark, 01-22-2006 09:15:07
Just to be sure it is only the nylon bushings, remove the coupling and start the engine to see if the noise does go away.Just remember you will have no hydraulics when you do.
