B coolant pipe
Doug L
01-21-2006 21:48:36
I have a 1953 B that WAS very near restarting for the first time in many years when I went to fill the radiator with coolant. I got to gallon number 5 when it started to pour onto the floor. Appears the upper coolant pipe (the one that attaches to the top of the head and onto the top of the radiator has a couple pin holes in the bottom. Pretty rusted out. Anyone know where to get a replacement? I see the parts section at YT has what they call a "Radiator Filler Neck", but I don't know if that is the same piece. Mine is stamped B2608R which is a different part number then on the YT site. They list the loweer water pipe but not specifically the upper pipe. Thanks for any help. Doug
johns48b
01-22-2006 14:30:42
 Re: B coolant pipe in reply to Doug L, 01-21-2006 21:48:36
try marlyn smith in iowa at 712-489-2570. he's got a lot of old parts and is a great guy to deal with. tell him john t in n al says hi.
Doug L
01-22-2006 08:21:54
Thanks to everyone. It appears that the muffler shop is the next stop. I do like that fiberglass idea though too. I'll try that on the old pipe for a spare in the future.
Jason Z in MO
01-22-2006 08:06:39
K&K sells the correct diameter pipe and is pre-bent. (I *think* muffler pipe has a slightly smaller diameter so they would have to flare each end)
Link
For your B I think the pipe is brazed into the casting manifold.
Ben.So.Tex
01-22-2006 07:39:36
Muffler shops can cut and taper them to where they fit.I have done this on 3 of my tractors.
Good luck Ben
SRA
01-22-2006 07:01:18
My "41 B had a pipe that was almost gone. Im took the muffler shop route and you cant tell the difference at all.
DickD
01-22-2006 06:42:19
Doug; I have run into the same problem on several old Deeres. I use liquid fibreglass. I give it one coat and let it harden good, then give it a second coat. Sand out the brush marks, if any and paint. Works for me.
james lee
01-21-2006 23:31:01
Doug, If there is a muffler shop in your area this would probably be your best bet they can cut the length you need and bend the pipe how ever you need it, I found this out when I went to our local Deere dealer looking for an upper water pipe for a 43 B they wanted 380 dollars I bout fell on the ground. Drove about a mile and spent 15 and got a pipe that i cant tell from original. Good luck
greenmech
01-21-2006 22:28:34
You could try a salvage yard for the pipe or remove the pipe from the casting and braze a new length of pipe to the casting.Ron Mn.
