I KNOW,ITS A REPEAT QUESTION.
TEXASJ
01-21-2006 20:33:06
her it goes. which oil, weight, and how much for the
engine
tranny(were is the fill location)
hydros(were is the fill location)
air bath
oh yeah its a 47 a.
thanks jason
Ben.So.tex
01-22-2006 06:55:43
 Re: I KNOW,ITS A REPEAT QUESTION. in reply to TEXASJ, 01-21-2006 20:33:06
Crankcase 30 wt 8 qts
tran 140 wt 7 gals Located at rear to the right of pto shaft 1 3/4" pipe plug. powr trol 30wt 6 qts located behind seat on top of power tro, Plug on top,,,some have a plug sticking out at a 45deg angle
cooling system 8 1/4 gals
air cleaner fill to the full line marked on the cup,
To get the screen filter out of the air cleaner I have never taken one out. I have away just wash the whole thing in a parts cleaner and that seem to work for me. Where are you located in Texas? I am south of San Antonio Good Luck Ben
Island A
01-22-2006 06:44:26
Early 47 or Late 47? There were 2 different 47 A's. I think my 49 -which would be the same as a late 47 model- takes 11 qts of 30 weight in the crankcase (or to the oil check cock), 28 quarts (7 gals) of 90 weight in trans (the fill is on the right side of the rear end cover), I used 30 weight in the powr-trol (fill to level of oil check cock, the fill is on the powr-trol cover with a square head) and 30 weight in the oil bath air cleaner. There is no filter in the air stack.
Dave
TEXASJ
01-21-2006 20:34:40
HOW DO YOU GET THE FILTER OUT OF THE STACK?
Lee B
01-22-2006 17:32:20
 Re: I KNOW,ITS A REPEAT QUESTION. in reply to TEXASJ, 01-21-2006 20:34:40
You don't. You just change the oil which is supposed to blow up into the 'air filter' media and bring the dirt down with it.
If that's not good enough you might consider removing the whole air cleaner apparatus and flushing it from above. Only other option is to start cutting it apart for media replacement and you are on your own at this point.
